Milspec Grommet Installation
Kyle Boatright
I went to install the grommets on my Milspec fasteners today. The holes in the cowl are the specified 15/32nds and I cannot persuade the grommets to snap into the cowl. I don't really want to go brute force on this, 'cause they are gonna have to come back off for paint.
Is the solution as simple as slightly opening up the hole with a round file?
Did mine today too; they were just barely undersized. Some light reaming with a deburring hook and smoothing with sandpaper was all that was needed.
Follow-up:
My Irwin unibit was about 0.020 undersized on the 15/32 step. Strangely, my Harbor Freight 15/32 centerpunch (one from a set of about 30 sized punches) was dead on...
Better relieve them a bit more for paint clearance. They can be a bit loose, the retainer will keep them in. And there's plenty of bearing surface on the outside.
