kbalch
I'm just about to order my Finish kit and, having thoroughly considered the options, decided to go with the standard main wheels and upgrade to Airstop tubes and either Air or Aviator tires.
Nosewheel-wise, I'm planning to use the Matco axle and spacers.
My remaining questions:
- Given the Airstop tubes, should I still plan to change the kit nosewheel for the NW511.25 in order to address valve stem clearance issues?
- Any opinions on Air vs. Aviator tires?
- Any concern on either of those tires properly fitting the wheel fairings?
- Is the same tire size used on all three wheels?
