Old 06-18-2017, 08:55 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by Chkaharyer99 View Post
This photo shows the Alt on the accessory case. No belt drive alternator detected. This option appeals to me for my consideration of the SDS system in that it removes the supposed vulnerability of the alternator belt from taking out the crank sensors.
Any downside to a system like this?
You need roughly 8-9 amps at idle to feed the EFI hardware plus whatever other loads you have. If you can do that with a a couple pad mounted alternators, it's viable.
Have not heard too much from Dave lately. He flying and doing some new mods for the Air Venture race I believe.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 426.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 06-19-2017, 02:34 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Mechanical pump use?
Ross: Is this still the load if a mechanical pump is used?
Thanks!
Old 06-19-2017, 07:08 AM
rv6ejguy's Avatar
Thanks!
No. Using a mechanical pump would drop the current load 4.5- 5.5 amps depending on the Walbro pump used.
Old 06-19-2017, 08:55 AM
rv7charlie rv7charlie is online now
Mark,
Are you asking about a stock engine driven pump? I don't know of any that will approach the 40+ PSI needed for automotive style injectors.
Ross,
Are you saying your system will work with the ~25 PSI from a Lycoming style engine mounted pump?
Old 06-19-2017, 09:17 AM
rv6ejguy's Avatar
Originally Posted by rv7charlie View Post
Mark,
Ross,
People are flying with modified aircraft mechanical pumps using our EFI. Fuel pressure needs to be in the 40 psi range.
We'll be offering a smaller electric pump in late July for sub 150hp engines. This reduces pump current draw from around 4.5 amps (normal medium pump) to 3 amps. Mainly offered for Rotax 912 and Jabiru engines which have wimpy charging systems.
We also offer a larger pump for engines over 350hp which draws around 5.5 amps at 40 psi.
Old 06-19-2017, 09:27 AM
Well, now I'm in Sgt. Shultz mode...
Can you share details on the mod to the Lyc style pump? Just increased return spring pressure? Which spring is used? Enough hours to tell whether there'll be problems with extra wear on the actuating cam & pump arm?
The automotive injection pump is the highest consumer of electrons, *and* drives the need for a mechanical bypass regulator, so if there's a way to do a diaphragm style pump driven by the engine, that simplifies both plumbing and electrical needs.
Charlie
Old 06-19-2017, 09:54 AM
rv6ejguy's Avatar
Charlie
I'm not sure of the mods done to the pumps, resultant life reduction etc. One is a Sport Class Continental which is a different design than the standard finger drive Lyc pump. I believe the Lyc users have fitted the Lear type rotary pumps.
Plumbing is not really simplified with the mech pump and you still need the bypass regulator to maintain proper differential over MAP for precise metering since pump output exceeds engine usage.
The twin electric pumps have proven to be 100% reliable to date if mounted and filtered as we recommend. The current draw is only a concern if you lose the alternator. We recommend either twin alternators (small vacuum pad one is fine for backup) and/or a backup battery with our EFI systems.
Old 06-19-2017, 10:32 AM
Chkaharyer99 Chkaharyer99 is offline
Ross,
Do you have a preference for 2 alt and 1 battery or 1 alt and 2 batteries?
I can see that Dave has at least 1 alt mounted on his accessory case but there may be a second one back there I can't see I these pics.
Any idea how his electrical architecture is set up?
Is it 1 alt 2 batteries?
Charlie
RV-8
Old 06-19-2017, 10:57 AM
rv6ejguy's Avatar
I'm not sure what Dave is using for electrical backup but he has a mechanical fuel backup to make enough engine power to get the aircraft to a runway if the EFI was to fail. His LS EIs would only draw 2-3 amps at cruise rpm.
Old 06-19-2017, 11:37 AM
That's a really cool feature Ross. I had no idea that option was available. I thought it was all electrical, no mechanical. That makes it more appealing. With
mechanical fuel pump only, what kind of performance could one expect from a lycoming IO360 with 9:1 pistons. Can you sustain flight? Or is it just prolong flight?
If you have documention on this feature, could you please send me the link where I can learn more?
Charlie
RV-8
