I have a left wing heavy situation, the left aileron is flying about 3/8 inch low for level flight. All control surfaces are aligned accurately with tooling holes in outside rib.
Question , if the light aileron is squeezed to correct this problem will the ailerons still be out of alignment, that is the left aileron will still be 3/8 inch low.
My thoughts are the left aileron is low to compensate for less lift on the left wing and therefore squeezing the right aileron will simply maintain the same aileron flying positions without the need for control stick pressure
Comments please
Peter
Comments please
Peter
