Hi Robert,
I had an Ellison on my original RV-8, and it worked quite well. I installed it along with the inverted oil system, as an alternative to fuel injection. I found that I could indeed lean farther than I had been able to with the carb, and that was without any of the flow straighteners.
If you decide you want one, I have an EFS-4 that came off an O-320 powered RV-4. I was told that it was used about 40 hours, and then the plane was upgraded to an O-360, making this too small. I bought it for a single rotor engine project that I'm working on, but have decided to stick with EFI. Email me off-list if you are (or anyone else is) intrested.
Rusty
13brv3 (at) bellsouth.net
