Old 08-17-2019, 01:58 PM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
Default Flap Tape removal
The anti chafe tape on my flaps is looking pretty rough. I've read on a few threads and picked up some new tape and one of the eraser wheels. I've read and been told that I would need to "drop the flaps" in order to get to it. At first, I thought this just meant lower them to their normal full down position, but the more I learn, it seems like I actually need to disconnect them in some way? Is this fairly straightforward?
Barrett
Smyrna, TN - KMQY
RV-6A
Learning something knew everyday.
Donated dollars - 2019
Old 08-17-2019, 02:07 PM
Kyle Boatright Kyle Boatright is online now
There is an internally wrenched bolt that attaches the flap pushrod on the root end of the flap. Take it out and the flap will drop to the point where you can remove the flap tape. Make sure you're holding the flap when you remove the bolt - it'll swing and hit anything in the way otherwise.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-17-2019, 04:23 PM
NYTOM NYTOM is offline
Thumbs up Very easy
Exactly what Kyle said !
Tom Norwood
Classic "Short Tail 6A” N822PM
Old 08-17-2019, 06:10 PM
ArlingtonRV ArlingtonRV is offline
Default I Did Mine a Little Differenter
The openings in the fuselage on mine were such that I couldn't move the rod far enough to get the bottom bolt out, the rod hit the fuselage opening. I ended up pulling the bolt at the top of the rod instead. A little harder because you have to open up the side panel on the fuselage interior. Also, I didn't want to work with the flap just hanging so I took them all the way off so I could work at the bench. That made the process much easier. It also allowed me to clean everything up since they had been on for about 17 years.
Before:
After:
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 08-18-2019, 04:45 AM
Talking Want to see more
Wow Steve , from what your showing it looks like a pretty neat paint job. Any chance of posting a photo of the whole plane?
Tom Norwood
Old 08-18-2019, 05:57 AM
BillL BillL is offline
You didn't ask, but here goes . . . Eraser wheels carry some paint risk and take a bit of labor. I removed HMW using a heat gun to warm it and peel off, then applied cut strips of (2) smooth paper towels, wet that with mineral spirits and one stripe of lighter fluid, covered the whole area with aluminum foil and let it sit for 4-6 hours. Ensuring it was not drying out. Then take off a foot or so at a time, scrape off the goo with a plastic razor blade or equivalent, using the still wet towel for the first wipe and a bunch of towels cut to 3" squares and lighter fluid for the final wipe. No paint damage and no residue.
It sounds harder than it is. 40 min to apply and 30 to remove, with a long gap for other work in between. Just ensure the foil does not allow the solvent to evaporate.
Naptha is Coleman stove fuel which I use instead of lighter fluid, and put the mineral spirits in a 99 cent clear condiment bottle from the dollar store. The spout makes for easy application for many uses, including belly oil removal.
Worth what you paid for it.
Bill
At Paint Shop
No Photo? => PM me.
Old 08-18-2019, 02:36 PM
Sure:
https://steverush.smugmug.com/My-New-RV-8
Steve Rush
Arlington, WA
RV-9 Tail
Old 08-18-2019, 02:57 PM
Sounds simple enough. I was gonna try to get to it today. Too hot to function right now though... Why do people live here again?
Barrett
Smyrna, TN - KMQY
RV-6A
Old 08-18-2019, 08:36 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Default Capt'n America
Originally Posted by ArlingtonRV View Post
This pic shows that the paint scheme on Steve's airplane extends to the underside:
Carl N.
Arlington, WA (KAWO)
RV-8, 675 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 08-19-2019, 10:45 AM
vfrazier's Avatar
vfrazier vfrazier is offline
I really like this stuff. It lasts for 10+years and doesn't yellow, peels off easily if needed.
I have heard that some guys say it's "sticky" if the skin sets on it too tightly, but I haven't had that issue. I suppose a bit of wax would cure that problem?
PPF flap kit
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
