Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #31
Old 11-03-2018, 01:24 PM
ArlingtonRV ArlingtonRV is offline
Originally Posted by Danny King View Post
If you own a GTX327 then the purchase of a GDL82 for $1800 is all you need.
The GDL82 contains the required WASS GPS and is simply installed between the GTX327 RF cable and the antenna. Then there's a power, a ground, and a serial to you altitude encoder source and you're done. Four wires!
I installed one in a friends RV-8. It was easy and strait forward. The GDL82 will work with other mode C transponders as well.
Danny, I will soon be mounting a GDL-82 in an RV-8. Where did you mount the box itself and where did you mount the GPS antenna?
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 11-04-2018, 05:48 PM
Originally Posted by Vansconvert View Post
When you write that the 330 is power hungry, can you please tell me how many amps? Thanks
From the GTX330 installation manual:
GTX 330 Power Consumption: 11-33VDC, 22 watts typical, 45 watts maximum
And...
GTX 330 Weight, installed with rack and connectors: 4.2lbs
By contrast (and I offer this only as one point of comparison, there are lots of other good choices available on the market these days)
Trig TT22 power consumption: 11-33VDC, typical 6 watts @ 14V
Trig TT22 weight: 0.77lbs including mounting tray
Old 01-08-2019, 07:44 PM
jdiehl jdiehl is offline
Default 327 software update
Originally Posted by uk_figs View Post
You can buy a used GTX-327 Xponder with tray for around $500, will work with the GDL-82 or microavionix ADSB out solutions. Garmin will normally update the 327 software for free at Oshkosh (you need the latest version to use with the GDL-82). Good Xponder, easy to use.
Figs
I知 getting close to ordering a GDL82 to complement my GTX 327 which is currently about 6 years old. I知 assuming (?) that it値l require a software upgrade. I haven稚 yet tracked down what software version is required. Any help would be appreciated.
Jim Diehl 7A
Based at KLHV (Lock Haven, Pa)
Old 01-08-2019, 09:56 PM
You might want to check with an avionics shop or Garmin. I just installed a GTX-327 that is at least that old, maybe older. I asked the local avionics shop if it needed a software update, he asked for the serial number and got back to me that it didn't need an update. I was happy since I was told the only way to get it updated was to send it to Garmin, through one of their dealers, and pay the flat rate for service.
Steve Rush
Arlington, WA
RV-9 Tail
Old 01-09-2019, 07:04 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Jim Diehl 7A
Hello Jim,
This posting for transponder updates at Oshkosh 2018 explains the latest software versions for the GTX 327.
http://www.vansairforce.com/communit...d.php?t=162400
Garmin dealers can quickly update the software, when needed. The transponder does not have to come back to Garmin.
Let us know if you have additional questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 01-09-2019, 11:04 AM
Originally Posted by g3xpert View Post
Hello Jim,
Steve
Good to know, I was obviously misinformed.
Steve Rush
Arlington, WA
RV-9 Tail
