RudiGreyling
Hi RVators,
OK I have the Avery Taylor Gun, and have just started using it. I have a couple of questions?
Q1) Adjustment?
Currently it pulls the rivets fine, but it does not automatically discharges the rivet stem into plastic holder. After I release the trigger the stem comes out forward by ?? or so. I need to push it out the back with another new fresh rivet. Sometimes it feels a little sticky and I have to operate the trigger a couple of times to loosen the old stem, before I can insert a new rivet?Should it Auto discharge the stem? Is this normal? How do I adjust it?
Q2) Cleaning / Maintenance?
How often to you open, clean, and lubricate your gun?
Thanks in advance,
Regards
Rudi
Q1) Adjustment?
Thanks in advance,
Regards
Rudi
