Old 02-21-2018, 11:49 AM
pvalovich pvalovich is offline
Default A New Old Thread - Updated ADS-B Performance
Indecision might be the key to flexibility, but I'm tired of pondering ADS-B options so have narrowed my options to:
1. Garmin: GDL 82, GDL 52R interfacing with Aera 660
2. echoUAT, SkyFYX-EXT interfacing with AFS 4500
Both options will interface with iPad/Foreflight.
Looking for updated real-world experience from those with either of these configurations. Correct me if I'm wrong but from previous postings it seems that Garmin performance is offset by Garmin pricing!
And there were previous echoUAT performance issues.
Don't want this to be viewed as a primer-war type issue, but both product lines have been available long enough to generate updated user comments. Thanks.
Old 02-21-2018, 01:14 PM
You might be better asking this question in VAF Forums > Avionics / Interiors / Fiberglass / ADS-B
[ed. I moved it there. v/r,dr]
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 02-21-2018, 02:32 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Echo UAT, SKYFX, AFS 5600T Works Great!
According to the FAA ---- traffic issues seem to be fixed with latest software upgrade by uAvionix AND the latest by AFS. Flown several hours with the combination and very satisfied (also get the ADS-B on my backup iFly740 through the WiFi from the Echo.)
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 02-21-2018, 02:58 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Default GDL82
A number us recently installed the GDL 82, works as advertised and works well with the 696/796.
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 02-21-2018, 04:49 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Figs
Now if we could just get that FAA rebate check to be delivered as efficiently as you did we would be set.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 02-21-2018, 07:18 PM
Paul 5r4 Paul 5r4 is offline
I have the echo device. At first there were issues with targets dropping out. I can report the software updates appears to have fixed this issue. Via wifi it works well with both my ifly 740 and a backup nexus tablet.
Great support from the company as well!!!
Paul Gray
Foley, Alabama
N729PG..... 300+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 02-21-2018, 09:09 PM
Chkaharyer99 Chkaharyer99 is offline
My RV 8 is equipped with an AFS 4500 and I contemplated a simular ADSB decision.
I decided to go with the Garmin 660 and Garmin ADSB in/Out option by way of a GTX 345 because the GDL 82 and 51/52 were not available when I made my choice. If this option was available, I could have saved some money and gained SXM capabilities.
Iím very impressed with the way Garmin displays traffic and WX. The ability to tap the 660 touch screen and get text METAR is fantastic. The audio alerts are great. Not sure how that would be achieved on the AFS 4500?
My ForeFlight rarely gets used in the cockpit anymore.
Charlie
RV-8
Old 02-21-2018, 10:41 PM
dabney dabney is offline
Default GDL 82
I am thrilled with my newly installed GDL 82. I received my rebate check in 3 weeks
The GDL 82 was fairly simple to install. I paired it with my old but reliable King KT76 transponder.
I had a Garmin 696 and GDL 39 already. The traffic displayed on the G696 is superb, target trends, altitude separation, and audible traffic alerts. I think the GDL82 is reasonably priced for what you get and what it does
Couldn't be more satisfied. Can't compare to your other option since I have no operational experience. I researched all the manufacturers ADSB solutions and this setup was the best
Paid for 2018 and well worth it!
Best investment I make all year....
US Army 1st Cavalry Division
LAPD helicopter pilot, retired
Old 02-22-2018, 02:55 AM
jliltd jliltd is offline
Why not pay less and have it all? Just take your Option 1 above and remove the GDL-82 and replace it it with the echoUAT. Woola. Now you have a configuration that is 2020 out compliant with any and all available "in". Including dual-band TIS-B and FIS-B, attitude (GDL-52 sourced) and SXM if desired. So you can choose any combination of your favorite device or app such as ForeFlight, Garmin portables like aeras, G3X, or GPSMAPs, iFly, FlyQ EFB, Avare, Garmin Pilot, Aerovie, Flightplan Go, Naviator, WingX etc.... You get the picture. Any kind of device the pilot or passenger(s) may like to use concurrently. And you will not be locked into one manufacturer's proprietary "in" protocol with the ability to change flight decks and portable platforms in the future.
I have an airplane with this set-up with the echo supported by a legacy King KT76A Mode C transponder, a GDL-52, an aera 660 an Android smartphone running iFly and an iPad running FlyQ EFB. It works great.
Jim
RV-8
RV-3B
Old 02-28-2018, 12:32 PM
94kb 94kb is offline
Default GDL-82
Installed GDL-82 last week in my RV-4. Replaced old Terra radio and xponder with used GTX327 and dual Becker 4301s. Replaced Garmin 496 with a 660. Previously replaced XM weather with GDL-39. Installed GPS antenna under cowl. Great install manual and easy installation. Good price and service from John Stark. Met all FAA performance on first flight. Installed anonymous mode switch and failure indicator.
After flying in uncontrolled airports and viewing other traffic with N number IDs, I am going to change the way I announce my position on CTAF. Normally I would state my position with yellow and white RV; I now see the advantage of using aircraft call sign to help others in correlating visual with ADSB position.
Kenneth Beene / Waco, Texas
RV-4 N63KB low wing
J-3 N2263M high wing
AS1 N777PJ bi wing
APRS WY0S
