After a search and not finding any pertinent info would appreciate input on these questions:
1. What Molex fitting style has Vans standardized on - Micro-Fit? Can?t find dimensions to match up male connector specifically concerning the wing tip wiring and the standard harness.
2. For Dynon Skyview builders, OP-55 (I am not using AeroLEDS, but Aveo Zip Tips) calls for a noise filter in left wing part ES-00184. I presume due to ADAHRS installation. Anyone not use it? Do you know a generic noise suppressor/filter that would work?
3. Anyone installed the Zip Tips and can share wiring tips?
Thanks.
Thanks.
