Old 02-13-2019, 02:57 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I've been researching the bigger tires since before I bought my RV-8. Very happy I found this thread.
RV-8 N52VM : Dynon D-180, GTX327, SL40, Garmin 496 GPS, AP74 Autopilot, Titan 0-360A1A2N, Nickel Coated Cylinders, 2 Slick mags (both impulse coupled), engine preheater, Hartzell Plane-Power alternator, Hartzell HC-C2YR-1BFP constant speed, blended airfoil
Exempt by 3 out of the 10 ways but I still donated.
Old 02-18-2019, 07:38 AM
flyinggreg1 flyinggreg1 is offline
If you want to go bigger yet I put a set of 21" on my RV4. No wheel pants then of course.
Old 02-18-2019, 07:47 AM
Pilot135pd's Avatar
What size are you using on the rear ?
Old 02-28-2019, 06:44 AM
KayS KayS is offline
I am close to install the whell pants on my 7. I intent to land on gravel/grass strips later and understand that a larger tire (like the 380) should help in that regard. On the other side i hate to throw stuff away and the installed stock tires do look perfect. So my questions to the guys who switched to larger tires: Is it really a noticable improvement during TO/landing on grass/dirt strips?
Kay
Old 02-28-2019, 07:42 AM
KAdriver's Avatar
KAdriver KAdriver is online now
Iíd say itís a noticeable improvement for soft field stuff. The grass strip I was once on was really soft and it helped a lot. If the grass you intend to visit isnít really soft I wouldnít bother with the 380ís. After I switched to the 380ís I developed a slight shimmy at around 30kts.
Jason
RV6
KASD
Old 02-28-2019, 09:34 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
This is a good thread:
http://www.vansairforce.com/communit...v-6+bush+plane
RV-7 Flying since 2004
1,000 hrs+
Old 02-28-2019, 09:40 AM
Lars Lars is offline
It was a noticeable improvement for me in rough/soft field ops. But it made the gear legs on my RV-7 shake like a paint mixer on landing starting around 30 knots, until I slowed to below 20. I tried balancing (repeatedly) and even another set of tires. The wood gear leg stiffeners offered for sale occasionally on this forum killed off about 99% of that. As is often pointed out, every RV is different. YMMV.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
700+ hours as of October 1, 2018
Old 02-28-2019, 10:06 AM
rocketbob's Avatar
rocketbob rocketbob is offline
They shake because they can be up to 1/2" out of round NEW. All aircraft tires are this way, even jet tires. My neighbor who flies/maintains a Falcon 900 changed the nosegear tires on his jet and it shimmied bad even after perfectly balancing them. He chucked them on his lathe, saw they were out-of-round and Goodyear sent him a new set of tires. He checked the replacements and they were minimally out of round. No shimmy.
The out-of-roundness is from where the plies overlap. That also forces the tire to have a localized stiff spot as the overlap patch is run over which also causes shimmy/oscillation.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 02-28-2019, 11:00 AM
Boy, I'll say. I've cut a tire open just to look. The overlap was ugly, though that was a sample of 1. My current set (Desser Aero Classic) is ok. Worst one was less than 1/4" out of round after sitting inflated overnight. Last set was noticeably worse, which was why I changed them. Were the Falcon tires tubeless? Wondering if that makes a difference on construction. Or radial, but I assume that's getting exotic for an aircraft application.
Lars Pedersen
Davis, CA
Old 02-28-2019, 12:20 PM
scsmith scsmith is offline
I've observed this too. Surprising to me. One would think they would manufacture tires that were more round. Seems like you would stagger the ply overlaps at various clock positions around the tire.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 550
also LS-6-15/18 sailplane
VAF donation Jan 2019
