Old 02-16-2019, 02:19 AM
hcccs's Avatar
hcccs hcccs is offline
Default Ray Allen servo power
How much current does a Ray Allen servo draw under full load? I failed to find this info anywhere.
Hans Stråhle
Jodel sold (SE-XEV)
RV-4, flying any day (SE-XJJ)
Färentuna, Stockholm
Sweden
EAA222
2019 =VAF= $20 donation paid
Old 02-16-2019, 06:37 AM
Default Considering
Considering the tiny, tiny wires...not much!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 02-16-2019, 07:49 AM
lr172 lr172 is offline
I remember it being an amp. Should be easy to verify with some searching.
N64LR
RV-10 in progress
Old 02-16-2019, 11:14 AM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
The Ray Allen servos draw approximately 150 milliamps no load, this from their web site. Can't imagine it's a very high number fully loaded, I wouldn't think more than 300 milliamps.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Helped build Bob Lund's airplane)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 02-16-2019, 11:57 AM
hcccs's Avatar
Thanks Pat. I'm driving my trim servo with a TI SN754410 H-bridge and it gives 1A output so it will be sufficient.
Hans Stråhle
Jodel sold (SE-XEV)
Sweden
EAA222
Old 02-16-2019, 02:25 PM
vlittle's Avatar
vlittle vlittle is offline
Hans, these drivers will lose about 2 volts in drive voltage, causing the trim motors to slow down. This may not be an issue for you, but if it is, let me know.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 02-16-2019, 07:36 PM
Raiz Raiz is offline
Default 800 milliamps
I was sure it was 800 milliamps but it took me a while to find the source. It's in the FAQs section on the Ray Allen website:
"What kind of circuit breaker and wire should I use?
The full stall current of the T2 and T3 servo is only 800 milliamps. "
