Fltplan.com Performance data
Hangar 1271
Does anyone have your RV-8 performance data loaded into fltplan.com for the advanced fuel burn table? If so, would you mind if I used your data as a donor for my inputs?
I would need your user name and tail number.
Thanks.
Not sure if this helps much, but there is an RV-6 in there... *similar* performance numbers, might be enough to get you started?
Yes. I think a 6 wold be a good starting point and maybe I should have put this in the General category since the 6, 7, and 8 are close enough to start from. There is also a generic 8 available but the numbers seem far too conservative (1000 ft/min climbs and10.5 g/hr fuel burns).
