Old 05-28-2018, 07:19 AM
Kupde Kupde is offline
Default First flight! and a question
First Flight
Saturday before the big Florida storm hit I was able to do a first flight. Everything went well with no big surprises. One question: my pitch trim works fine on the ground but in flight I found that at cruise that it wouldnít move past neutral to allow me to trim it out completely. For some reason it showed power going to the trim as I pushed the switch but it wouldnít move past neutral. Tried it again on the ground and it worked fine. I have a VPX system and Iíve input the positions with plenty of space on each end of travel so not sure hat it is? Any suggestions welcome.
Kevin
Old 05-28-2018, 09:22 AM
Congrats Kevin!!!!!!
Tom
Ridgeland, SC
Old 05-28-2018, 10:00 AM
Default Congratulations
Originally Posted by Kupde View Post
First Flight
Kevin
Kevin, big congrats on the new fledgling
Old 05-28-2018, 10:06 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
Congrats on your first flight!
The VPX might be slowing down your trim motor too much when your airspeed gets higher. I don't have a VPX, but I built a similar speed sensitive trim controller, and when you get it too slow it doesn't have enough power to overcome flight loads on the trim tabs and the trim motor will stall. Speed it back up a bit and it should be fine.
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 450 hrs
Old 05-28-2018, 11:20 AM
rongawer rongawer is offline
It might be that the stops are configured in the VP-X different than the PFD (Iím assuming you have an EFIS).
The VPX software has a trim configuration tool. I recommend connecting a laptop to the VP-X and cycling the trim to see what the VP-X thinks is going on. Itís likely just a setting. If youíre using a G3X, there are additional settings for trim in the configuration tool there as well. I imagine Dynon and other APís have the same.
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
Old 05-28-2018, 12:17 PM
RV3bpilot's Avatar
RV3bpilot RV3bpilot is offline
Very nice, first flight, Cooooool....
Sorry I don't know anything about electric trim...
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
318 hours and counting
Old 05-28-2018, 03:50 PM
Thanks for inputs. I think itís like Lenny said the speed power reduction at higher speeds, so Iíll set to a higher limit and see what happens...
Kevin
Old 05-28-2018, 08:42 PM
pilotkms pilotkms is offline
Default Dynon?
If u have Dynon Skyview with VPX u need to go thru the calibration procedure. Both need to know which one is in charge. Had same issue with my FLAPS. Made for exciting first flight.
Keith
RV 7A RV #9700
N325KS the Flying ďKĒ
Built in SoCal KCCB, now @ KPXE
270+ Hours & 5x cross the USA
2018 OSH - yes
Old 05-29-2018, 09:02 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
If u have a G3X gea24 you need to disable the speed sensitivity in the VPX as shown in the vpx manual
Bill Peyton
RV-10 - 890
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
