Addicted to the site?
Donate yearly (please).
Advertise in here!
Today's Posts | Insert Pics
Old 11-07-2009, 10:06 AM
Gagarin737 Gagarin737 is offline
Default Flaperon slight curve in trailing edge
Today I finished both flaperons. Left flaperon had a perfect straight trailing edge, the right flaperon had a "curved" trailing edge. When I connect a string from tip to tip then I measure the curve as 3/16 in the middle. It's highly visible when you look along the trailing edge.
I guess I have no choice with all the prepunched holes.
Had anyone the same "problem"?
And anyone an idea how to correct this?
Joeri.
MyKitlog
Picasa pictures
Old 11-07-2009, 04:37 PM
Geico266's Avatar
Geico266 Geico266 is offline
The flapperons were one of those parts you have to get a little rough with to get them to cleko togeather if I remember right. They should be straight as an arrow. I would get a hold of Van's. IMHO this is a problem.
Let's be careful out there..........
Larry Geiger
RV-10 = For Sale http://geicodevelopment.com/n203jj
RV-12 = For Sale http://geicodevelopment.com/rv_12
Old 11-08-2009, 07:36 AM
Contact Van's tomorrow, thanks for the feedback. The fit was perfect at this flaperon so it's strange that I ended up with this.
One of those moments....And I'm even not building from plans, respect for those builders.
MyKitlog
Picasa pictures
Old 11-09-2009, 01:04 PM
Default Lucky again....
9-11-2009 Measured the right flaperon again. The spar has a deflection of about 3/32 of an inch.
After placing the flaperon on the wing (and "forcing" it in the flaperon brackets) the flaperon is completely straight!
MyKitlog
Picasa pictures
