Originally Posted by RGaines
The sensor is in fact a 3 wire unit and is not a resistive type. My question is why would they substitute a simple resistive $25 part with a complex $400 part that has a potential to fail (12 hrs)?
I think only the Rotax people in Austria can answer that question with any certainty, but I suspect it is related to making the engine ASTM compliant.
The original resistive sensor is too big in diameter to allow a standard AN style hose to be attached to the oil pump inlet.
I am sorry that you have to deal with this frustration but the reality is that the plain jane resistive sensors are actually quite prone to failure.
Because of your certainty that the sensor is bad I have to assume you have verified the wire continuity from the sensor all the way back to the connector at the D180?
