Hi Doug,
I have always had good luck and service with retreads from Desser - good prices, excellent tire wear. I've been using them on my planes for over 20 years - never had a bad one.
Paul
Yes but the question is......did they send you the correct inner tubes to match the tires?
Whatever you purchase, DO NOT assume that the tire and inner tube are a match. Call the tire manuf or go online to check the part numbers then tell them what part numbers you want!!
Recently I posted about this issue.
THE TUBES
500-5 MICHELIN AIRSTOP TUBE (TR-67 VALVE)
Unit Price In Shopping Cart
59.95
OR
500-5 INNER TUBE (SHORT 90 DEGREE VALVE)
36.95
Not Common. Used on some older aircraft and experimentals. [/COLOR][/I]
Once again, thanks for the help!
didn't really intend to hijack this thread. just...err...borrow it.
Go with the Michelin Air Stop tubes. You'll never regret it. You won't need to add air between annual condition inspections.
