Old 11-25-2017, 08:19 PM
E. D. Eliot E. D. Eliot is offline
Default White Tint for Epoxy
Posting this question for the group as I can't fine the answer with the search mode here. I'll bet that the answer is here, I just can't find it - sorry.
I'm going to put a final coat of epoxy inside of my cowling and want to use white as it will show fluid leaks, etc., well.
Went down to West Marine hoping that they would have the answer as to which product to use and they said that they couldn't recommend any of their products for my cowling interior.
Tried Home Depot. They gave me about 1/3 pint of their fluid tint that they use to color the paint that they sell. This is right out of the tinting machine and is water soluable. It mixes well with my West Systems epoxy so I gave it a test try on a small area inside of my cowling a couple of hours ago.
My question is have any of you used this tinting product from Home Depot and did it work out ok? is there a better product to use as a tint? Please advise. Thanks very much.
Building finally
Old 11-25-2017, 08:41 PM
rv9builder rv9builder is offline
Two possibilities:
https://www.westsystem.com/501-white-pigment
http://www.aircraftspruce.com/catalo...?clickkey=3581
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 11-25-2017, 09:44 PM
DrillBit's Avatar
DrillBit DrillBit is offline
I used the stuff from Tap Plastics. Local store, no mail order delay.
Kurt Haller
P-town, CA (10 min from KLVK!)
N748PK, RV-9A
Airworthy as of 21 January 2019
VAF dues last paid 9 Dec 2018
Old 11-25-2017, 10:16 PM
bruceh's Avatar
bruceh bruceh is offline
I used the West System 501. It worked great and is meant to be mixed with their epoxies.
Bruce Hill
RV-9A N5771H flown over 600 hours!
http://www.overthehills.com/RV-9A-Project
APRS Tracking for KJ6YRP and New Flying Blog
2019 VAF donator
EAA Tech Counselor
Old 11-26-2017, 04:09 AM
mike newall's Avatar
mike newall mike newall is offline
Artists acrylic paint - cheap, simple, works.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2018
Old 11-26-2017, 04:18 AM
Dean Pichon Dean Pichon is offline
Titanium dioxide is the most common pigment used to make paint (or epoxy resin) white. The water soluble solution from Home Depot likely uses this pigment, but I would be hesitant to add it to a non-water based resin. You should be able to find powdered titanium dioxide such as the West material referenced in an earlier post.
Good luck,
Old 11-26-2017, 09:43 AM
Default Thank you
I appreciate all of the info given. I'll head back to West Marine today and see if they have 501 since it seems to be the safest appropriate answer. Thanks again - Ed Eliot
Building finally
Old 11-26-2017, 11:42 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
System Three also sells tints for epoxy resins.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 11-26-2017, 11:53 AM
tim2542 tim2542 is offline
Iíd suggest just a good quality epoxy paint in gloss. Thatís all I have on my Cozy cowls and it cleans nice but needs a little scrubbing to get into the weave. Anything else you do will add weight.
If thatís not important you can fill the weave with dry micro, sand, wipe with West epoxy to fill pin holes and paint as above. The micro wil be white, but still needs to be sealed with a good epoxy paint.
Gel coat would be a good choice except itís heavy.
Tim Andres
Old 11-26-2017, 11:28 PM
Default Update - today
As many of you suggested, the Home Depot tint did not work. Mixed up ok but I was not happy with the somewhat rough finish. It's in the 70s here and the epoxy took about 24 hours to set up which is slow here.
Went back to the West Marine store and they did not have the 4oz container in stock. But for $24 plus tax, they would have been happy to sell me enough tint to do 3-4 gallons of epoxy. They weren't particularly interested in my business so I ordered the West Systems white tint on line.
Incidentally, if any of you have recommendation on which roller or paint brush with WS epoxy, I'm all ears. I'd like to finish the inside of my cowl in a high gloss, smooth finish. Suggestions please. Thanks, Ed Eliot
Building finally
