Page 18-05: Flaperon rivet question
AeroDog
Friend
When riveting the A-1207 actuator bracket to the A-1203 flaperon spar, depending on how you orient the rivet, either the shop head or the manufactured head will contact the curvature in the bracket (see pic). I don't want to machine a flat surface in the bracket because that would weaken it. I'm at a loss. Any advice will be appreciated. I read the other posts on this, but I still don't know how to deal with the shop head hitting the curvature.
Jerre
x3qZ2rZNrh6Hty_IDloqUjg7MBkt15NZ6l0GqcKrcOw0d0jyU30GUL1Ga9b1O9BjVmQSwye39G68iqoqhlqBH101nWU_gYrXskkcyQLpbN-YK1ZIwxe7XaBJIhJklecrl2drwhfn9GrP051kA_hLkQdkQidwYYIlFHKbTbkoRH6KusIsd1uDoOZoaCIA79gFBB6CsAyLonG0ckhDnZL1NmKA63ZnMTPeAx4XejBAiz5oWeodBZHCbHyj26BQ4HGPn5Tr0Wrs-za4Yy84Zg0U6N619AyPSQ8XOJEyLd6znWC0SlyEc7NjHiOk7ymlv576swtCnGXtV5Txs2iyFzUvfCqtihGFznwsGWFGjxmSFTICXdyhQLS-XcFlicwjCf1hFvtSFOuetHcN0UPwra7RPH9pgywCEjGwQxxu1frxcvU12HH3LbUQMSiF693yLl7HK0V7SErRUyiLcz596-GuUpuWZMvk7dibEKqhjog7DTLe25TPSrbPCc-lPboAkEauxo8JLvbAPDJHmed16vNRmg-CO8TyDtDPaF0z5cKgJcAwJkiUz-qON2whWvvv4hk7jxJOI6XkRhydnq5smDGYA2SekdnH7ds=w640-h480-no
I figured it out. Ground and beveled the flat on the squeezer, then spaced it out with washers.
UsYyXqz_xBWE1LFxfOWEqo52aT7Mf6eHgbFeeew8butqpmtY5EHalR1xMgztt1dZABOe6to5nypIaBwAM9Vq3zwMkHQXYrAkKksw1pzXc2uks4mOyT_QEil1cpV8wSRtlSMAH_jm1tg5keuPuljoBtvqvD_sVw_OVbi4hl_2sRK5t5x8r5sxOdtz3l6hUp2NXiQ5C-qVqEktNLEiVpJVqjpr9JHILCyqKTXETsmOyW3qlyb_wa45gZkDH8zNmpVxPkOf2e4jtzv5SDnDfpF-HmvIRmjlP6LmTuTLnkw7Wpsk9RK2QB6xYJ1u_NPRxELgPSsUSQ-l_JBQmNXL1yH_DswsERWdCxfCgVtgYWyIMii2icgTCLMu2oqwUUyM_xcrURAsV0mFeC5QX9kzJYXZLE6YkpOUcODsdfnl9Wy6KBlc_tQhlcRmqohgFS3Rnt41IY5GPgOfwsKZxGoKGJbvFl_loav9dc53Jz0TYBXaeP_63WOi27h60AiK6224jAu_MzSLzOKPp7XaQwAbMr1pNl3jOObtDoA2yW9v12EJNwIZ8bhR-WOv5CfxpxJBt8YRCcox66mU5_7QukN35vJG5f7aHKKYaJ4=w640-h480-no
I wouldn't over think it. If you get a good shop head you should be OK. A good rivet joint is designed to be in shear not tension.
