Need help calibrating AOA. Have an RV7 with G3X. Stall speed full flaps is 47kts. I normally fly instrument approach at 100kts, if in pattern 90kts base, cross end of Rwy at 70kts.
Have tried to set AOA calibration using minimum visible at 90; caution at 60; stall warning by doing power off stall full flaps. Seems to calibrate successful at end of each but when setting target AOA, reports AOA calibration is invalid.
Have tried several times in smooth air but single pilot. Any help will be appreciated. Any suggested speeds will be appreciated. Garmin support suggested minimum visible at 1.5 stall which is approximately 75; caution at 1.1 stall - 53; target at 1.3 stall or 72.
