Hi All, i have the Dynon pitot tube with AOA and tried to calibrate it. The pressure (or better vacuum) hose of the measuring equipment gets connected to the pitot tube. So far so good. But what should be done with the second lower opening for AOA on the pitot tube? Should that one be closed with tape or so? Background is that my skyview did show weired readings when the hose was put over both openings.
Best Regards from Germany
Kay
Kay
