Old 01-25-2013, 09:06 PM
Bill R,
Perhaps the 650 fixed the Zenith wing problem, but as Dirty Harry would say: Do you feel lucky? :-)
Rich
Old 01-26-2013, 06:01 AM
Alschief Alschief is offline
Default CH 650 VS RV 12
We have a partially completed CH 650 and a flying RV 12.
Each design has it pluses. The Zenith kit will require more assemble preparation.
The RV is a very mature kit. The RV piece parts require little additional preparation and the instruction documentation is very thorough.
We also have a two Zeniths in our hangar (601 and a 650).
Contact me off line if you know someone looking for partially built CH 650B
AL & Brenda Smith
RV12, UL Power N495BA Flying
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 07-17-2018, 11:40 AM
johnr9q johnr9q is offline
Default questions
Kitplanes, in their buyer's guide, states the following: Number built and flown: RV-12: 398, CH 650: 528; Build time RV-12: 800 hours, CH 650: 500 hours; Useful load RV-12: 580 lbs, CH 650: 625 lbs.
Some of this conflicts with what I read in these forums. Anyone have better information? Are these stats valid or does Kitplanes have a bias toward the CH 650? 45 lbs more useful load for the CH 650 is significant.
Old 07-17-2018, 12:47 PM
Can't speak directly to the 650 or the RV12, but am peripherally involved in a 750 build. The level of completeness of the Zenith drawing set is, at best, disappointing and does not match up with the company's advertising about the maturity of the kit. We spend more time trying to figure out the drawings than actually building the airplane. Many of the folks involved are repeat builders, including at least two plans builders, so there's no lack of know-how, just a huge lack of clarity and completeness in the drawings. Revision tracking in the drawings is simply awful.
Old 07-17-2018, 05:53 PM
Correct me if I am wrong but the following are some of the differences that I find in the RV-12 and the CH 650:
RF-12
More of them flying
More robust company
More robust forum
Easier to build
Easily removable wings
Higher resale value
No wing falling off issues history (CH 601)
More mature kit
CH 650
Cheaper
Supports a Parachute
Fuel in wings
More engines supported
Can build as a tail drager
Old 07-17-2018, 06:41 PM
You mention the CH601. If I remember correctly, the 601XL had multiple fatalities from in-flight breakup. One aircraft lost a wing in cruise flight and another lost a wing in the traffic pattern. The FAA took a very unusual stance for experimental aircraft that no AWC would be issued for this design. Zenith charged customers several hundred dollars for a wing "fix" kit.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 429
LSRM-A Certificate 2016
and MJ Stricker (Flight Instructor) - 1st Lt./Captain B-17H
Old 07-17-2018, 09:04 PM
AirHound AirHound is offline
The 750 Cruiser format is slowly making it into the ranks, IMHO. Is there a good market for a Vanís high winger of sorts to be designed?
Safer with gas in wings and flip over egress.....maybe a low priced high wing SLSA trainer. Or, are they limited to just low wingers?
Doug
Old 07-18-2018, 10:48 AM
dothetime dothetime is offline
Default 650 vs RV12
I fly an AMD factory built 601XL.
No aircraft that have had the upgrades have had any breakups.
The 650/601's are real bargains due to their tarnished reputations as their value has never recovered.
I purchased my Factory Built aircraft for a fraction of the cost of a RV12, and for less than the cost of a unbuilt kit 601/650.
I'm sure the RV12 is a better aircraft, but for the price of a factory built or kit built 601/650, you can't ignore the difference in prices. Its a lot of bang for your buck. I have mine registered as an ELSA, it originally was an SLSA.
I also prefer an air cooled, direct drive engine.
David Krakowsky N601XP
Old 07-18-2018, 12:25 PM
j-red j-red is offline
I built a 601xl for less than 25k. I just donít think that could be done with the 12, even if starting with a used kit like I did. Maybe the biggest reason for that is two-fold. First, there is the tarnished reputation the XL reducing the cost of even second-hand unfinished kits, and second s the ability to use alternative engines. Both result in lower cost to built and both contribute to lower resale value and more difficulty locating a buyer, even with the beefed up wing mods installed.
In summary, if the lowest possible cost to get two people in the air at LSA upper limit speeds is the primary objective, then I donít believe there is a batter way to achieve that objective than a used Zenith kit.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 07-18-2018, 12:54 PM
Pardon my saying so, but these parts just don't look like enough beef to keep wings from falling off...
EAA #499867
