Old 03-31-2012, 01:16 PM
Av8torTom's Avatar
Default Fuel Pick-up
I don't like the soft 3/8" OD aluminum tube used for the fuel pick-up inside the tank. Any reason not to use stainless steel? Is it difficult to bend and flair?
Tom
RV-9A (empennage completed, both wings completed, fuselage and finish kit completed, engine hung, working on panel and wiring)
N677AT reserved
Superior XP O-320, 160HP
Old 03-31-2012, 01:24 PM
terrye terrye is offline
Default Aluminum Tube
There are two possibilities for the fuel pickup tubes, the sawcut ones as shown in the plans and the optional ones in the accessories catalog online which have a finger screen safety wired and prosealed to the tube. Consider the latter for your tanks. I think the type of sawcut/screen is more important than the type of tubing.
In answer to your question, yes, stainless steel is much harder to flare and bend. If you want a better material than the soft aluminum tube in the kit consider 5052-0 in the ACS catalog, it is a much stronger alloy. In any case, whether 3003-0, 5052-0 or stainless, the material should be annealed or
"-0" temper for easier fabrication.
Terry Edwards
RV-9A (Fuselage)
2018/2019 VAF Contribution Sent
Old 03-31-2012, 01:34 PM
Av8torTom's Avatar
Default Saw cuts
Terry, yes - it's the saw cuts that bother me. Seems like the end could easily break off after a while from vibration.
ACS has 5052-0
OD ID Thickness Part number
3/8 0.305 .035 03-39500
Think I'll order some of that and see how it is.
N677AT reserved
Old 03-31-2012, 01:45 PM
longranger's Avatar
longranger longranger is offline
I was more worried about their performance as a screen than them breaking; I never heard of that happening. I'll be using these from Vans on my -7. You might want to talk to them to make sure they'll work in a -9 tank.
A fine mesh screen is safety wired and prosealed to the tube.
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 03-31-2012, 01:57 PM
Av8torTom's Avatar
Default Doesn't say
Miles, it doesn't say that those fuel pick-ups are specific to any model does it?
T.
N677AT reserved
Old 04-01-2012, 08:47 AM
longranger's Avatar
T.
Correct. I would hope that means they fit all models, but I would call Van's to make sure. The -9 does have a differently shaped tank/leading edge.
Construction Log
Old 04-01-2012, 10:27 AM
rv9aviator rv9aviator is offline
I used the ones from Vans on my RV-9A and they seem to be fine. I didn't care for the saw cut way of doing it either.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 04-01-2012, 10:29 AM
krw5927 krw5927 is offline
The pre-made Vans pick-ups with the nice mesh screen fit my RV9 tanks just fine. The tubes are the same soft aluminum used throughout the fuel system. A little light bending to get the pickup to sit a few thousandths off the bottom of the tank is all it takes. Maybe I should have bent them to sit ON the tank bottom, but figured I didn't want the mesh rubbing on the tank bottom from vibration. Anyway, the point is, the pre-made fuel pickups are quite nice, decently inexpensive, and fit the 9 just dandy.
Kurt W.
RV9A
FLYING!!!
Old 04-01-2012, 02:45 PM
Av8torTom's Avatar
Default Thanks!
Thanks everyone - I just put my order in.
T.
N677AT reserved
Old 04-01-2012, 03:02 PM
BSwayze's Avatar
BSwayze BSwayze is offline
You'll be glad you ordered those from Vans, Tom. I put them in both of my tanks and I like 'em.
Bruce Swayze
RV-7A Standard Build
Working on Wiring and Panel!
Dues Proudly Paid for 2016
http://www.BrucesRV7A.com
