Old 08-10-2018, 03:01 PM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Removing N-Numbers / Decals
I want to change my N-Number. I've accomplished the paperwork but now I have to actually change the numbers on the airplane! I thought these decals would just peel off. Wrong! I think maybe they have been clear coated. Scraping with plastic razor blades isn't working. Heating with the heat gun isn't working.
I'm afraid to try the chemical approach. Any ideas?
Randy
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through Jan 2019
Old 08-10-2018, 03:12 PM
Mark Dickens's Avatar
Call Jonathan McCormick. 256-490-1541.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 08-10-2018, 04:52 PM
snopercod's Avatar
They make Vinyl Decal Remover Wheels. I have no idea if they work and I definitely would want to try them on something else rather than my airplane.
(2018 dues paid)
Old 08-10-2018, 06:27 PM
Larco Larco is offline
Recommend having someone of experience look at it. It should be easy for an experienced eye to tell if they are just vinyl or clear coated over or painted on. Then you can form a plan of attack.
Old 08-10-2018, 07:04 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Paint?
My painter used the vinyl numbers that I supplied as a mask for the paint. The whole plane was painted white. Then the numbers were applied. Next, the red paint was applied over the vinyl and finally, the vinyl removed leaving behind white numbers on a red background.
It would require a re-paint to change my numbers.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 08-10-2018, 07:15 PM
tim2542 tim2542 is offline
Yep, those things will scare you but they work fantastic without damaging the paint.
Tim Andres
Old 08-10-2018, 11:25 PM
deene deene is offline
Eraser wheels work extremely well and are easy to use. A little pricey at you local auto paint supply outlet.
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 08-11-2018, 02:27 PM
UH1CW2 UH1CW2 is offline
If they are a paint match to the white on the aircraft, they are most likely painted on. If they are an off-color get a magnifying glass and look close at the edge of one of the numbers, you'll be able to tell if it is paint or vinyl clear coated over.
Phil Camarda
US Army 2nd/17th Air Cav 101st Airborn
A&P, Commercial & Instrument Pilot
Airplane Multi & Single Engine Land
Helicopters (UH1's, AH1's, S76, H269)
Test Pilot (Military)
Long EZ Driver but love RV's
Dues Paid 5/18.
