Old 08-10-2018, 09:41 AM
gacnik123's Avatar
gacnik123 gacnik123 is offline
Default Left cheek heat
Helping a friend with his new build RV 4 cabin temperatures. Oil cooler is mounted behind rear left cylinder and engine temps are good. We seem to be taking in the heat, that is exiting oil cooler, through the left cheek. Metal near where the throttle cable comes in is hot to the touch. Are you guys building little walls inside the left side to prevent this? Looking for ideas? Thanks John
RV-4
N36WG
Take off is optional, landing is mandatory... Keep all your landings intentional...
Dues paid 2019
Old 08-10-2018, 10:38 AM
Default What I did..
I mounted my cooler in same place, but I built aluminum close-outs that cover the cheek opening. They are simply pop-riveted in place, and make the area much cleaner and more internally aerodynamic. Simple 2 hr. job.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 08-10-2018, 12:17 PM
AX-O's Avatar
AX-O AX-O is offline
I also blocked mine. Made it as part of the cheek to give it rigidity. Sorry for the poor pic. Could not easily find a pic of just the cheek.
Axel
RV-4 fastback thread and Pics
VAF 2019 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 08-10-2018, 08:23 PM
gacnik123's Avatar
Thanks guys much appreciated! John
RV-4
N36WG
Dues paid 2019
