Old 08-10-2018, 09:34 AM
rvmv rvmv is offline
Default tip up with a wet compass?
Would like to hear where those with tip ups put their compass. Thanks
Old 08-10-2018, 09:48 AM
flyinga flyinga is offline
Wet compass is not required. A "magnetic direction indicator" is required. If you are installing glass instruments, that will include the required indicator. I do not have a wet compass in my plane.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 08-10-2018, 10:26 AM
catmandu's Avatar
catmandu catmandu is offline
Before I cleaned up my panel, it was top center of the panel, to the right of where the old six pack used to reside.
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 08-10-2018, 11:07 AM
Default Rephrase
I guess I should have phrased the question better. If you put a wet compass on the glare shield of a tip up when it is raised it tilts the compass to close to 90 degrees? Does that hurt the compass? Thanks
Old 08-10-2018, 11:25 AM
odens_14 odens_14 is offline
I put a cheap automotive compass I bought from walmart up there when my FAA inspector insisted even though my EFIS has a magnetic indicator.
anyway, 8 years later and its still there and I've noticed no negative effects of the tip up. but again this is a $10 walmart version not a more expensive aviation model.
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Build Log
Old 08-10-2018, 11:56 AM
kyhunting kyhunting is offline
Mine is on the glare shield. No problem other than it vibrates a little.
David
RV6A
O-320
Donated 11/2018
Old 08-10-2018, 12:01 PM
Caveman's Avatar
Caveman Caveman is offline
I've had one of these on the glareshield of my tip up for 10 years with no issues at all:
http://www.aircraftspruce.com/catalo...2400Campus.php
The other posters are correct that it is not required. But some kind of magnetic direction indicator is.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
VAF Dues Paid through 2018
Old 08-10-2018, 12:09 PM
Mel's Avatar
Mel Mel is offline
Only for nighttime or IFR operations. For daytime VFR nothing is required.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 08-10-2018, 03:08 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
This just kills me...
2019 Dues paid!
Old 08-10-2018, 03:51 PM
yeah....I wasn't very impressed either. It crossed my mind to argue, knowing it wasn't required; but decided it wasn't worth it and just stuck one on with the intention of taking it off, but it's still there
Chris Odens
Alexandria, MN
RV-7 N914N
Build Log
