Old 08-10-2018, 07:18 AM
larrys larrys is offline
Default RV-14 fuel redundancy question
Building the RV-14, the fuel pump is over the outgoing exhaust tunnel. Does it get hot? And also we are planning for backup electrical power but what about a backup source of fuel pressure? Does the Lycoming 390 have a manual pump and the one in the tunnel is only a lift pump? Should it be more accessible?
What are other doing to make redundant system for fuel? Is monitoring fuel pressure part of the Dynon package?
Thanks, Larry
RapidsetBuildings.com (Hangars)
Advertiser
RV-14 tail, QB Fuselage, Finish kit, QB wings and FF kit, Thunderbolt 390 (in line for delivery), Hartzell C/S Blended Airfoil. Sill need to put it together... 90% left to go
Grateful to pay dues 19'
Old 08-10-2018, 08:37 AM
mturnerb mturnerb is online now
The engine has a mechanical (primary) fuel pump. The electric fuel pump is redundant (it is used for priming and for failure of primary pump). This fuel system is consistent with the design of most certified single engine aircraft.
To my knowledge (following forum closely) the location of the fuel pump hasn't been reported to be an issue in terms of heat gain. There is pretty substantial airflow and separation between exhaust and tunnel walls. Fuel can vaporize in fuel lines firewall forward causing issues with hot starts but "hot start" procedures usually easily overcome this.
I know Dynon/G3X etc have fuel flow monitors - not sure about fuel pressure but they may be manifestations of the same thing....
Turner Billingsley
RV-14A FLYING!!
Old 08-10-2018, 08:38 AM
RV-14E's Avatar
RV-14E RV-14E is offline
The IO-390 drives its own fuel pump.
Mine came with Lycoming part no. 62B26931. The electric boost pump is used for priming prior to (cold) start or in case of the engine pump's failure. It's also reasonable to run on takeoff and is typically part of your landing GUMPS check.
E
http://rv-14a.blogspot.com/
Old 08-10-2018, 08:41 AM
Default fuel,
I am really grateful for the replies!
It makes sense to me now.
Advertiser
Old 08-10-2018, 09:00 AM
Ron B. Ron B. is offline
Yes , the Skyview is capable of monitoring fuel pressure.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 08-10-2018, 11:07 AM
Default fuel monitoring
Thanks! I will get it done
Advertiser
