Old 08-09-2018, 06:30 AM
Karetaker Karetaker is offline
Default Pitot Location
I have a Piper Blade type pitot that I was planning to mount on the square access plate used for the stall warning kit. This moves the pitot out onto the leading edge as opposed to having it near the wing spar. I am curious if there would be airflow issues in this area giving me inaccurate air speed readings?
Old 08-09-2018, 08:44 AM
jcarne's Avatar
jcarne jcarne is offline
I would think there would at least be a little bit of error as that access plate is angled up a bit compared to where it is usually mounted. How much error I don't know.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 08-13-2018, 01:58 PM
Raymo's Avatar
Raymo Raymo is offline
Plans call for the pitot tube to be 6" below the wing surface. I don't think it would work well on the leading edge.
Some have used that area for their AOA probe (hollow rivet).
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 08-13-2018, 02:46 PM
Walt's Avatar
Walt Walt is offline
I would suggest you do yourself a favor and get a standard pitot mount and a Garmin Pitot tube GAP26 ($199) and then you will have a "standard" install. I've removed plenty of non standard installs that somebody thought was a "better idea" that didn't work or looked like ****.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 08-13-2018, 08:08 PM
219PB 219PB is offline
Default Pitot Tube for sale
Karetaker,
I have a new in pitot tube, never installed. I installed a Dynon unit. PM me if you interested. I will make you a good deal.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2019 Dues Gladly Paid
