Old 08-10-2018, 11:50 AM
rocketbob's Avatar
rocketbob rocketbob is offline
Originally Posted by scsmith View Post
When epoxy crystalizes in the container, just warm it up a little and stir. No harm done. Not sure it would be good to put it in a microwave though.
I've been using Shell DPL 862 for years and pump it out of a metal can. When it crystallizes I just put the can on a hot plate set on low for an hour or so and that takes care of it. In colder temps I will pump 862 into a paper mixing cup then nuke it for 5 seconds. Thats all it takes to give it water-like consistency.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 08-10-2018, 01:21 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by F1Boss View Post
...Epicure 3234...
...Also known as straight TETA, Is hands-down the most sensitizing hardener I have ever used. Back in the bad old days we used a lot of TETA with Epon 815C resin, a mix we came to call "Redeye." Now I just think of it as an epoxy allergy distribution system.
https://en.wikipedia.org/wiki/Triethylenetetramine
As Steve notes above, in our shop we use Jeffco 1307/3176 mix from Aircraft Spruce. Yeah, if you want drum quantities of it you can probably replicate it from 862 or 832, or even 828 (the base resin for those stocks), with standard Epon diluents. But it's probably not cost effective unless you need lots, and some of the diluents are pretty nasty chemicals.
The MGS 285 or 335 system is nice because it carries the EASA/LBA stamp of approval, but the properties are about the same as the Jeffco.
[Edit add: Steve already hit all the high points]
--Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
