Old 08-07-2018, 09:13 PM
Eric B Eric B is offline
Default Looking at the RV-12, have a couple questions
I *was an RV-10 builder, but life came along and now those little feet need something to do. Why not build a plane?
First, I sold all the tools along with the kits and components a while back but the longeron yoke was my favorite for the pneumatic squeezer. Would a pneumatic squeezer be a benefit on he RV-12? I'm thinking of all the nutplates. Would a longeron yoke be useful for those?
Secondly, how much room is there behind the panel before you get to the subpa el? Looking to add an IFR navy to the mix, maybe Avidyne and the dimensions say it is 11" deep.
Thanks in advance! Looking forward to getting back. Hopefully.
There are only 10 kinds of people in the world, those who understand binary and those who don't.
Old 08-07-2018, 09:33 PM
rongawer rongawer is offline
You won’t use a squeezer as much as you would on a -10, but you will have plenty of opportunities. I have a longeron yoke, but I haven’t used it on the -12; like you said, lots of nut plates, and several other solid rivets you can squeeze.
For the avionics, I have a GTN625 and it fits fine (the GTN650 and an IFD540 have the same dimensions). The connector will be a tight squeeze, so I recommend a right angle connector for the extra clearance, but it will work with a standard DB connector as well.
Ron Gawer
- RV10, N1530G (reserved). Empennage in progress.
- RV12, N975G, "The Commuter"
Old 08-07-2018, 10:12 PM
I added a VOR/ILS by hanging a small sub panel on the main instrument panel centerline underneath the instrument panel, so if you are worried about panel space you do have an option to expand it.
Old 08-07-2018, 10:56 PM
Driftdown Driftdown is offline
Pictures? . .
Old 08-08-2018, 01:14 AM
rv9builder rv9builder is offline
The new RV-12iS fuselage has a center console for fuses, throttle, switches, etc. This frees up space on the main panel for more avionics. You can see photos at these two links:
http://flyrv12.com
http://flyrv12.com/aircraft/the-new-rv-12is/
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 08-08-2018, 04:56 PM
12vaitor 12vaitor is offline
I managed to squeeze an IFD540 into my RV-12 panel and there is almost no clearance at the firewall side even with 90 deg coax connectors. I ended up with just over a finger width of space. Also had to build a custom mount/rack frame and one-piece panel with front insertion of the 540 and a Garmin GTR200. I also reinforced the panel base with a 3/4" angle across the base to handle the 11lbs of extra weight. Plan ahead for all the wires, especially all the coax (5 or 6 cables) that go down the tunnel.
John Salak
RV-12 N896HS
Old 08-09-2018, 12:00 AM
Driftdown,
I have not had much luck posting pics. Send me your email on a PM and Iíll send you the pics.
Rich
Old 08-09-2018, 12:26 AM
greghughespdx greghughespdx is offline
Our (new) RV-12iST SLSA trainer model has a GTN 650 in the panel, so yes - it fits. You'd need to carefully research how to properly register and certify the aircraft assuming you actually wanted to operate it in IMC of course.
Van's Aircraft - Director, Community/Media
Van's web site | Instagram | Facebook
Opinions, information and comments posted by me are my own unless stated otherwise. They do not represent direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XPIO-360
VAF build thread - Flickr photo album - Project Facebook page
Flying spam can, helped build/fly a few RV-12s and some other RVs
Hillsboro, OR (EAA 105)
