Old 08-08-2018, 06:47 AM
sandifer sandifer is offline
Originally Posted by iamtheari View Post
Any tips on the breather issue? I noticed that the "slobber tubes" on the Great Lakes planes that I got to fly for my introductory aerobatics lessons last winter made a lot of "slobber" after the inverted lessons, so I inferred that the inverted system kept oil going to the engine but didn't keep it off of the belly of the plane (without help from the tube to the tail, that is).
Aerobatic planes route the breather all the way to the tail so that any dribble will not end up on the belly. Even with a full inverted system, the "slobber pot" will still allow a small amount of oil to dribble out during and for a short time after a flight with a significant amount of positive/negative G transitions. But without it, you'd pump a lot out. There's a lot of info on this site. Search 'half raven' if you only want to contain oil.
the advice I am getting on that is that, if you have to ask the entry speeds for loops and such, you shouldn't do them
Agree there!
I will say that I didn't get addicted to sustained inverted flight or inverted spins, but I would really enjoy a hammerhead right about now!
It's not about getting addicted to 'sustained inverted' or inverted spins - that is simply incidental to more advanced aerobatics, should you become interested. 99.9% of RV pilots who do aerobatics just fly the basic loop, roll, Cuban, hammer, spin figures, and you don't need any inverted systems at all for the usual RV acro. If you want to compete, and maximize you potential, there are other considerations. Unfortunately, only more aerobatic experience will tell you how far you want to take things, and exactly what style of flying you want the airplane capable of.
Old 08-08-2018, 07:02 AM
Ari--we havent done any inverted oil systems for the 14 yet, but similar systems on the 6, 7 & 8 as well as several other experimental models. Plumbing it is no issue.
I would suggest getting mockups or really good dimensions of the tank and ball valve before you buy anything. The location of the oil cooler might hinder the right (co pilots side) install location.
You might also talk with Allan Barrett on the sump situation.
Tom
Ridgeland, SC
Old 08-08-2018, 07:35 AM
Danny King's Avatar
Danny King Danny King is offline
Originally Posted by Aluminum View Post
Danny, is your oil accumulator plumbed in addition to the inverted scavenging, or did you remove the inverted system entirely?
From the apparent size of the oil accumulators google brings up it seems that they would provide a fairly short burst on a Lycoming before they run out?
The Christen inverted oil system is still installed, so the Doll can fly continuous inverted flight. Still, with a Hartzel prop that is spring loaded to low pitch, I still need the accumulator for protection against zero G when the Christen oil flop valve stops between positive and negative positions. A good example is when doing a Hammer head turn when on the up line the aircraft is at zero G.
The accumulator is plumbed to a #6 AN fitting given to me by Bart at Aero Sport engines. It replaced the cap fitting at the top of the accessory case oil passage way.
Consider this when making your decision. The oil/air separator function of the Christen system also switches the breather between positive and negative G flight. The oil/air separator tank returns most (but not all) of the oil back to the sump.
Unless you plan continuous negative G flight, the accumulator should handle momentary pressure loss.
Danny King
Beautiful Doll 80434 TT 1600 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2019
Old 08-08-2018, 08:46 AM
Kansas7 Kansas7 is offline
Find a parts book for the new extream decathlon. It uses an IO390 if you duplicate that setup and propeller you should be good.
Old 08-08-2018, 02:32 PM
mike newall's Avatar
Watch Jim's hammerheads.......
https://www.youtube.com/watch?v=I4MFxXrih_M
I learned that 80 is fine for an upline and it keeps the belly dry. I can get 2,000' upline at 190kts, 2g pull to 80 and a dry belly.
Hesitations, slow rolls, cubans, all OK, provided as earlier correspondents have said, just keep a gnats of positive on. Adds to the technique discipline...
Donated in 2018
Old 08-08-2018, 03:21 PM
More like removes technique discipline.
Old 04-29-2019, 07:36 AM
sheldon957's Avatar
sheldon957 sheldon957 is offline
I wanted to resurrect this thread to see if someone has installed either a full or half Raven on a 14 with the IO-390, and if you installed after construction. I am tired of oil on the belly, but there isn't a whole lot of room under the hood for more installation and wanted some pictures of a completed project.
Old 04-29-2019, 07:41 AM
iamtheari iamtheari is offline
I was going to resurrect this thread sometime this week, anyhow. I have mostly decided on a half Raven and an Accusump oil accumulator. However, I am having a really hard time pulling the trigger ordering those because, until I mount the engine, I have no idea where or even if they will fit.
I also want to put on a 90-degree oil filter adapter. My Arrow oil changes already frustrate me and it has a lot more space between the oil filter and the firewall than the RV-14 engine mount looks to afford. But again, I don't know if it will fit.
I hope someone has pictures of these various items on an RV-14 to share.
Old 04-29-2019, 08:13 AM
M McGraw's Avatar
M McGraw M McGraw is offline
... I hope someone has pictures of these various items on an RV-14 to share.
This the only picture I could find of the Half Raven installed in my -14. The tank is installed where the battery should be; the battery has been moved between the subpanel and the firewall. You can see I added an access panel. The tank needs to be high and on the opposite side of the engine from the return line; therefore, you will likely need to move the pressure sensor manifold and firewall penetrations or the battery. Another option is to attach it to the engine mount, but that makes it harder to mount it high. I seriously doubt you will have room for all the other stuff you are considering.
The Half Raven has served me well, I have never put oil on the belly.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 275+
2019 Dues Paid
The Dues Paid note is a reminder for me
Old 04-29-2019, 08:48 AM
sheldon957's Avatar
Looking at the parts for the half Raven system, it appears just to be the tank and the adapter for the oil return.
Trying to understand what size fittings and hoses will have to be ordered to complete the install. On the Raven directions, it gives the tank openings as "larger ¾” NPT fitting is up and the smaller ½” NPT is down", and would need male fittings into the tank. Then a female is needed for the attachment to the included sump adapter. I would assume it is a 1/2" female.
Did you use 3/4" hose or ? (guessing I.D.) or different sizes needed, and what lengths would be needed?
