Old 08-06-2018, 03:37 PM
Stockmanreef Stockmanreef is offline
Default 38-23 Drilling Canopy Question
Should I remove the plastic protective wrap on the canopy along the part that rests on the back part of the canopy along the roll bar assembly (not along the rails--I already removed that)? Or is it Ok to leave the plastic covering in place?
On 38-21, it does state to peel back some of the covering on the front edge of canopy. But nothing stated here.
Just wondering if it impacts the way the canopy sit on the arch portion of the canopy assembly. If one does remove, I imagine that I should recover with tape.
Ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 08-06-2018, 03:59 PM
Atanyspeed Atanyspeed is offline
Although the plastic is pretty thin, I removed it to get as tight a fit I could. You’ll soon be countersinking the holes to fit to fuselage.
Craig Wheeler
San Diego, CA
RV-7A Sold
14A Flying
Old 08-07-2018, 04:33 PM
RV-14E's Avatar
RV-14E RV-14E is offline
Page 38-21 states:
"NOTE: The best fit can be obtained by ensuring that only the bare surface of the canopy directly contacts the aircraft structure."
May I also suggest that you consider sealing the forward edge of the rear window where it contacts the Roll Over Structure. On my first flight through rain, there was water ingress in that area. I outlined my approach here. I used siliconized latex caulk (because it's paintable - be careful what you use). It's not visible.
Please also consider painting the perimeter of your rear window where it contacts the F-01474 Aft Fuse Top Skin. If you don't, the sealant will be visible and its aesthetic may not be desirable. I outlined my approach here.
Prior to final install...
Final install...
You might also consider putting a tiny bit of sealant along the skin joints on the exterior too, to prevent water ingress. I did this for the Rear Window and Canopy. Below is shown the Rear Window. I outlined my approach here.
Sealant application...
Very clean looking edges after sealant application...
Finally, I had to use a pair of additional washers to keep the surface profile of my Rear Window correct (i.e., prevent it from forming a depression) where it meets the F-01432A Roll Bar Brace. Without those extra washers, the Rear Window curvature in that area would 1) droop downwards and 2) not match that of the Canopy. Also, as you can see below, it's clear that this area is a great place for water ingress if not sealed as I outlined above.
E
http://rv-14a.blogspot.com/
Old 08-07-2018, 04:43 PM
I saw that on 38-21, then it states to peel back on the same page. Then nothing about the area around the roll bar area. I was just weighing the option of the firm contact versus me scratching up the inside of the canopy after removal of the covering.
Thanks for the reply and the heads up not where to apply sealant.
Ken Stockman
Midland, MI
Old 08-07-2018, 06:13 PM
Response from van's was that it doesn't really matter if you peel it back. Of course I already did it.
And again, thanks to E for the heads up on where to put adhesive and paint.
Ken Stockman
Midland, MI
