Old 08-06-2018, 03:42 PM
Mick RV7 Mick RV7 is offline
Default Mounting Park Valve in RV-7
I'm trying to make a decision on how to mount the park brake and I noticed on a tread that someone suggested mount it on the firewall where the fittings protrude through the firewall. I thought what a great idea.Anyone have thoughts and photo's
Old 08-06-2018, 05:21 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Here is where mine is located.
https://www.dropbox.com/s/lb9xvmn29e...70081.JPG?dl=0
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 08-06-2018, 07:17 PM
I have a PVPV-D park valve and was thinking of mounting it where the fittings come through the firewall which would mean using different fittings can anyone help?
Old 08-07-2018, 08:34 AM
Mick-- you can move it up alittle from the tri gear bracket, and fab up 2 rigid tubes to connect the the bulkhead fittings. Will also shorten up the 2 pressure out hoses accordingly.
Most of the RV7/9 installs we've been a part of put it on the firewall like the the RV10 location.
Tom
Ridgeland, SC
Old 08-07-2018, 10:02 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
I mounted my parking brake valve in the cockpit on the firewall forward of the pilotís left rudder pedal.
http://mykitlog.com/users/display_lo...=185474&row=16
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePO.
Wrap by AircraftWraps.Com. Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
