Old 08-06-2018, 02:02 PM
iamtheari iamtheari is offline
Default Relay doubler for Vertical Power PPS (part FF-01402 / page 27-07)
I am planning to use the Vertical Power Primary Power System (PPS) in my RV-14. I am beginning the firewall section of the fuselage kit and wondering if there are any adjustments I should be making to the relay doubler installation in order to accommodate that system. Looking forward to page 43-01 of the firewall forward kit plans, the master relay and starter solenoid are both intended to be mounted on the relay doubler, using two bolts each into the provided nutplates.
I could fashion a replacement for the FF-01402 Relay Doubler using the PPS template as a pattern. But anyone who has got that far into the plane would know better than I if there is room for the PPS in that position and if there are better places to mount it.
Thanks in advance to anyone who has gone before.
Old 08-06-2018, 03:04 PM
bschweinberg bschweinberg is offline
Default RE: Relay doubler for Vertical Power PPS
I was also planning to use the Vertical Power PPS. I used the doubler that came with the kit and attached it per the plans. As for the PPS, this is what I am thinking about doing, with an emphasis on "thinking"
I am thinking about riveting two aluminum angle brackets together in a "Z" shape. So two of these (i.e. four aluminum angles making two Z brackets). The length of these would be the same length as the PPS. The Z brackets would be bolted to the existing holes where the relays would normally go. When mounted like this, the width of the brackets should match up to the width of the PPS mounting holes.
I'd have to go back and look at my scratch napkin drawing again, but I think a "Z" bracket consisted of a 1"x1" angle riveted to a 1"x1.5" angle, with the 1.5" side where the PPS would be mounted. This was needed so that the PPS mounting holes could be drilled with enough edge clearance on the bracket.
If I end up scrapping the PPS, then I can still use the standard relays and mount them on the doubler as per the plans.
Bill Schweinberg
West Chester, OH
N2814X Reserved
RV-14A Started Nov 2013
Builder #140100
Empennage/Tail Cone DONE! (95%)
Wings In Progress (90%)
Fuselage In Progress (75%)
Finish Not Started
http://www.mykitlog.com/bschweinberg (not up-to-date)
=VAF= 2019 Dues Paid
Old 08-06-2018, 03:27 PM
Sam Staton Sam Staton is offline
Default Long wait
I have been planning to use it as well. Current data indicates that it will not be available until early 2019. Not happy.
RV6 N585SS - building on!
O-360-A1G6D converted to A1A
Dual Powertek EFII
VPX-Pro
Hartzell C/S
Dynon SV1000 & SV700
Old 08-06-2018, 03:36 PM
With that data, I will install the stock relay doubler and built a bracket for the PPS per the other reply above, if and when I have a PPS in hand. The worst-case scenario that way is to fly with traditional relays until I get a PPS and have time to rewire for it. (The rewiring won't be a major thing to accomplish if one plans ahead.)
