Old 08-06-2018, 09:19 AM
fr0gpil0t fr0gpil0t is offline
Angry Pneumatic riveter setup
I cleaned out my HF pneumatic riveter and can't seem to get it setup right. It rivets fine but it seems to flattening the face of the rivet. As though it's pulling the rivet too hard or if the stroke length is too long?
I turned the air down to about 40 psi and tried to loosening the lock nut and adjusting the jaw assembly either forward or back but it doesn't really seem to make any difference.
Does this sound like the stroke length if so how do I shorten it?
Robert
Old 08-06-2018, 11:34 AM
I think that the force against the surface of the rivet is determined by the breaking point of the rivet stem, aka mandrel. Whatever adjustments are made to the rivet puller should not have much affect.
Joe Gores
RV-12 Flying
Old 08-07-2018, 10:59 AM
AEA AEA is offline
Is the nose of the rivet gun profiled to match the head of the rivet? Maybe that would help.
Aaron
Old 08-07-2018, 09:18 PM
Mine were flattened a little by my HF riveter. After 765 HRs and 6 1/2 years no rivet issues.
Old 08-07-2018, 09:25 PM
rcarsey rcarsey is offline
hey they ain't called Low Profile LP rivets for nothin!
Old 08-08-2018, 02:34 PM
mike newall's Avatar
Check the diameter of the tip hole versus the mandrel diameter.
We drilled out the smaller tip to match the mandrel and it gave much better results.
Donated in 2018
Old 08-08-2018, 11:11 PM
The only issue I found with nosepiece hole diameter was when I got lazy and used a 3/16 nosepiece on a 1/8 rivet. That caused the head to extrude into he nosepiece. I learned what the Ghost Busters referred to as an important safety tip.😜
Old 08-10-2018, 12:55 PM
actually.. I think i've had this problem myself too.. the hole being a little too large for the LP4-3's .. I did pretty much the entire airplane thinking that this was normal.. because it was the smallest nosepiece that came with my gun.
i borrowed my neighbors gun for something recently and saw that he had a smaller nose piece..that was an exact fit..
did i shoot myself in the foot here? or before painting, can i just take a piece of sandpaper and go over the heads real quick so as to knock the little extruded/sharp piece of the head off?
Old 08-10-2018, 03:12 PM
Unless they really stick up Id leave them alone. If they are really bad you may want to talk to the rivet manufacturer and see if it compromises their strength. A nice coat of paint hides a lot of cosmetic booboos!
