Old 08-06-2018, 01:05 AM
#74430 #74430 is offline
Default Compatibility - Dynon / Garmin
Hey lads,
Just wondering if someone can help me with this question....
I have installed Dynon AP servos and heated Pitot... Will Garmin avionics be compatible? Has anyone else done something similar.
I was originally planning to install a Dynon fit-out but would still like the option to do either.
I'm not keen on replacing what I currently have.
Any thoughts?
Dan
Dan
RV-7A
Empennage and Wings complete....
Fuselage - Building canopy and firewall forward.
Sale, VIC
Australia
0404 869 261
Old 08-06-2018, 06:33 AM
Brantel's Avatar
Brantel Brantel is offline
The Dynon servos will not work with the Garmin systems.
The pitot can be used with either.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-06-2018, 08:27 AM
airguy's Avatar
airguy airguy is online now
Correct, Dynon screens will talk to Dynon servos and Garmin screens will talk to Garmin servos - but you can't mix them.
You can run a Dynon Skyview EFIS to drive the autopilot servos and use an ARINC-429 to interface between the Garmin and Dynon screens, so you can fly a coupled approach from the Garmin.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 08-06-2018, 12:05 PM
rleffler's Avatar
rleffler rleffler is offline
The Dynon servos will work with AFS screens as well.
AFS is probably a more equivalent comparison to the Garmin in my opinion.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 08-06-2018, 12:15 PM
Brantel's Avatar
To clarify/further add to Airguy's comments, yes you can use the GNS or GTN series Garmin IFR Navigators as a navigation source for the Dynon gear (with the appropriate interface). You just can't use the G3X/G3X Touch system to control the Dynon servos nor can you use the Skyview system to control the Garmin servos.
The Dynon servos are stepper motors and use the Dynon DSAB bus for communications. The Garmin servos are brushless DC servo motors and use the Garmin version of CAN bus for communications. Two totally different servo and communication methods.
Old 08-06-2018, 12:25 PM
mfleming's Avatar
mfleming mfleming is offline
You now know the Gamin and Dynon servos can not be interchanged BUT you do not have to replace your servo brackets if they are already installed.
The Garmin/Dynon brackets are pretty much the same and can be used for both brands of servos. Dynon and Garmin apparently copied True Traks mounting system.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 08-06-2018, 12:40 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Dan,
I have Dynon SkyView classic and Dynon A/P servos, plus a Garmin GTN650 nav system. The GTN and SkyView interface through the ARINC module beautifully, giving me a great IFR RV-7A IMHO.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePO.
Wrap by AircraftWraps.Com. Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 08-06-2018, 05:07 PM
Thanks for the info guys.
Good to know that I can swap out the servos and use the same mounts. The last thing I need is to create more work.... I'm already dreading starting the canopy.
Appreciate it,
Dan
Dan
RV-7A
Sale, VIC
Australia
0404 869 261
Old 08-28-2018, 10:59 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Garmin in General is VERY proprietary.... not only servos.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
