Old 08-04-2018, 06:38 PM
JDA_BTR JDA_BTR is offline
Default Transponder doubler
Is a doubler necessary or optional for the transponder location under right baggage compartment? Plans included one for com 1 and 2. Inclined to not worry about it.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 08-04-2018, 07:08 PM
Tom023 Tom023 is offline
I just made one today and used the cork gasket to get the holes laid out. Took all of 15 minutes.i l redid the com ones too. The plans have you rivet them on but the four holes used for rivets are where the antenna screws need to go through. I put nutplates on the backside.
RV14A #140083
Down to last 1%. Targeting June 1 for first flight.
2018 Donation+
Old 08-04-2018, 11:14 PM
RV-14E's Avatar
RV-14E RV-14E is offline
For the antennas that are directly underneath the baggage area, I chose not to include doublers, when I installed my ADS-B receiver antennas.
I reasoned (perhaps incorrectly, after all it's 0.025" skin), that they are blade antennas with a small profile...
Unlike the two communications antennas up front, which do have doublers on 0.04" skin.
I did put a doubler on the big Garmin GPS antenna (the doubler template can be found in that link)
E
http://rv-14a.blogspot.com/
Old 08-05-2018, 08:28 AM
I also built and installed a doubler for the GPS antenna on top. I installed it with the small head rivets with a slight countersink in the skin to avoid having to dimple. Usually I use those NAS rivets for nutplates. Worked out great.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
