Old 08-03-2018, 03:17 AM
autoglide autoglide is offline
Default Electric aux fuel pump ?
Have an O-320 Lyc 150 hp carb engine. Need to install an elec pump. Donít want to use a Facet, as the mounting plate plus inlet/outlet is oriented wrong for my installation .
What other brands/models are typically used ?
MB
Old 08-03-2018, 05:11 AM
Default More details ?
I am trying to picture your installation quandary as you describe it, as the little Facet cube pump is about as simple as it gets. I have 2 in my -4, one is in the tunnel beside the battery, and the other I have on the firewall plumbed in downstream of the gascolator, which I run continuously as my main fuel pump. I have an O320H2AD 160hp which has no engine driven pump. The Facets can be set up with whatever fitting you need on the inlet and outlet side, and mounted in just about any orientation.
Bill E.
RV-4/N76WE
8A7 / Advance NC
