Old 08-01-2018, 04:35 PM
Randy333 Randy333 is offline
Default Pop rivet gun
I heard Avery tools is closed. Where is a good place to buy a air powered pop rivet gun
Randy
Old 08-01-2018, 04:51 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Default "pop rivet" tool
Brown should have them. They're a sponsor here.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 08-01-2018, 05:51 PM
rv7charlie rv7charlie is online now
I've had one of these
https://www.harborfreight.com/3-16-i...ter-93458.html
for about 15 years. I haven't built an entire plane with it, but it's served me well building a hangar door, multiple other random projects, and for all the pulled rivet work on my -7 project.
No doubt there are better pullers out there, but sometimes better is the enemy of good enough.
Charlie
edit: HF now has a higher powered version:
https://www.harborfreight.com/14-in-...ter-62685.html
Old 08-01-2018, 05:55 PM
Gandalf Gandalf is offline
Randy
I used the wrong tip on my pop rivet gun from Avery and I called Avery and the fellow there was able to set me straight and back working. Talk about great support. Sorry to see Avery close.
Jeff
Old 08-01-2018, 06:19 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
I got mine for Harbor Freight. For my RV7 it has been fine.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
rvblog.thebrices.com
Old 08-01-2018, 07:04 PM
flysrv10 flysrv10 is offline
Here is another option. I like mine a lot.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-01-2018, 07:32 PM
DRMA DRMA is offline
I tried using the HF rivet puller a couple of years ago. Went through 2 different tools, neither of which worked properly. Returned them and bought a better tool (Dayton brand if I recall correctly) which has worked well.
However, if I were going to build a complete RV-12, I think I would spend a few hundred $ for one of the high end "Pop" brand rivet guns or equal. I had the chance to use one when I was building my empennage at Synergy Air and the differences were very noticeable. A very smooth pull, lighter and smaller, and with a vacuum holding the rivet in place in the nose piece and pulling the stem into a flexible catch tube. With as many rivets as I think there must be on the 12, I personally think spending the extra money would be worth it.
Good luck with your new project.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 08-01-2018, 08:02 PM
rk2436 rk2436 is offline
The red Taylor brand gun works great. Don't bother with the cheap HF one. It's not worth the aggravation when it keeps on breaking or burping oil all over.
Old 08-01-2018, 09:38 PM
I bought two Harbor Freight guns. That way when one started malfunctioning I just swapped guns, and then fixed the bad one later so I always had one in standby. My friend only bought one and has good luck with about 30% of his project done with no issues. Seems like HF rivet guns are a bit of a **** shoot in reliability.
Old 08-02-2018, 04:13 AM
mike newall's Avatar
ATS is our best gun, with a HF as standby. We have built two RV12's simultaneously, so plenty of pulls.
Spend some time checking the hole size to match the rivet mandrel. Our first rivets were leaving a sharp edge because the hole in the tip was too big, the smaller was too small !
Figured out in between and drilled the smaller one out - then it ran perfect.
Also, keep it clean and lubed, you will pull thousands of rivets and every month, it benefits with cleaning the jaws, re lubing with T-9 or similar. Takes a few pulls to settle down, then good to go again.
Harbor Fright gun needed filling with oil - that was a right PITA......
Donated in 2018
