Old 07-31-2018, 06:28 PM
AeroDog AeroDog is offline
Default Vy versus best glide speed
Looking at the latest POH, Vy is given as 75 kts and speed for best glide distance is given as 63 kts. I've never seen a spread this large between the two speeds in other aircraft I've flown. Does this square with what people with flying airplanes are seeing?
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2018
Old 08-06-2018, 01:51 PM
flytoboat's Avatar
flytoboat flytoboat is offline
I have read that best glide speed is typically about half way between Vx and Vy.
Don
VAF #1100, EAA864
-6A bought flying
Old 08-06-2018, 03:29 PM
Scott Hersha Scott Hersha is offline
On my RVís, Vy and best glide was very nearly the same: 80-85 KIAS, depending on GW & air density. This should be approximately your best lift/drag speed which of course varies with density altitude. If you have an AOA, you can program this, but a target indicated airspeed is usually close enough.
SH
RV-8
Cincinnati, OH/KHAO
Old 08-06-2018, 05:05 PM
In an ideal case they should be the same. Real world, most of the difference comes from prop efficiency - typically prop efficiency is a strongly increasing function of airspeed, in this speed range. Especially for fixed pitched props.
Old 08-06-2018, 08:35 PM
49clipper 49clipper is offline
Default 49clipper
In my flight testing of my RV-6, Vy came out about 95mph. Best glide was sort of hard to nail down, but I use Vy that also. Seems to work out well.
Jim
Old 08-07-2018, 10:36 PM
Marc Bourget Marc Bourget is offline
Those speeds are also dependent on weight. It might be worthwhile to investigate the effect weight makes in your initial test period(s)
Old 08-08-2018, 09:46 AM
Default 49clipper
I did test at the weight that I fly at 90% of the time. If at gross, I will add a knot or two.
