Old 08-01-2018, 08:11 AM
joedallas's Avatar
joedallas joedallas is offline
Default Aluminum Tie Down Rings
I will fly with my tie down rings
http://joesrv12.com/Builder%20Log/al_20_01.htm
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 08-01-2018, 09:19 AM
Default Nice!
Those are nice. Be sure to use a lubricant on the threads as aluminum/aluminum tends to gall pretty easily...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 08-01-2018, 03:00 PM
Bob Y Bob Y is offline
So no concern regarding the strength of those using aluminum? Shear strength if side loaded when tied down in a heavy wind? And there is a gap between the bottom of my threaded tie down extrusion and the bottom surface of my wing skin. Do you have a sleeve spacer around the top of the bolt?
Old 08-01-2018, 09:49 PM
DaveWelch DaveWelch is offline
Very very nice Joe. Much better look than those cheesy steel loops I got Lowe’s aviation supply. So...what would a fellow -12 builder have to spend to obtain 3 of ‘em? If you just want to “rough them out” then I’ll do the finishing and polish.
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 08-01-2018, 09:54 PM
Default The OP question
I keep the wing tie downs in the map box and leave the tail one installed. It has saved some skin scrapes while loading on a trailer.
Hadn’t thought about the corrosion, now I’ll have to go look.
RV12 N951DZ
Old 08-01-2018, 11:22 PM
Tony_T's Avatar
Tony_T Tony_T is offline
I took my tail tie-down ring out today. It's been in there for 7 years. I use it to ground the airplane when fueling as well as a tie down. I installed it with Loctite on half of the threads. There was no corrosion.
The shiny part of the threads is where I cleaned the dry Loctite off. I also ran a 3/8 X 16 tap in the aluminum hole and it went in with only light force on the tap handle. It came back out quite clean with no evidence of corrosion.
I consider it a non-issue.
Tony
RV-12 #202 -- Flying
Old 08-02-2018, 07:59 AM
joedallas's Avatar
Default Custom Parts
Thank Dave
My focus is finishing my aircraft and testing all the changes I have made to my 12.
I enjoy working on my Lathe and Milling machine.
I have had request for custom parts and I will make them for other builders after I finish my aircraft.
I will add a page to my web site and list the parts and drawings of custom Items available.
I will be starting my Jabiru 3300 Gen 4 engine soon and hope to be flying by November.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 08-02-2018, 08:54 AM
EXflyer EXflyer is offline
Default Radius
I see no radius at the base of the threads it should have one there and another thing is the sharp root of the threads will be a weak point. If you notice the tie down ring shown it has rolled threads with no sharp root. Also if one uses a thread lube such as copper coat on the threads will take care of things.
Old 08-02-2018, 09:07 AM
Joe, in post #21, you link to this photo:
If this is a sample of your tiedown rings, please, at least generously (as much as possible) round the edges of the rope hole. Rope has decreasing strength when the radius is small. In that sense it's a bit like aluminum.
Old 08-02-2018, 02:21 PM
joedallas's Avatar
Default Details not in first post
There is a 1/4" at the end of the thread that is .374" and the hole in Vans bracket is taped to 1.5" deep using a 3/8" 16 Pulley tap and then Counter bored to 3.75 inches about 5/16" deep for the tail cone and on the wings they have a two step shank 7/16" 3/8" deep and the .374"1/4"deep to allow them to be in contact with vans Brackets and not contact the wing skins
Also I have chamfered the hole, However I use S hooks at the end of my tie down ropes
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
