Old 07-30-2018, 05:03 PM
AeroDog AeroDog is offline
Originally Posted by rocketman1988 View Post
Yep, better remove any dissimilar junctions throughout the airplane!
Including all nut plates.
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2019
Old 07-30-2018, 07:17 PM
Scott Hersha Scott Hersha is offline
TD rings slow me down about 15 knots,,,, I think...... feels like it anyway.....
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 07-30-2018, 08:15 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by benfra View Post
Good Hint! Yes electralisis still exists!
Exactly
All the other steel parts are coated, including the nutplanes and don't cause dissimilar metal corrosion.
Go ahead and leave those tie down rings installed and then try to remove them in a few years and report back. It will only get worse over the life of the airplane.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-31-2018, 08:57 AM
AirHound AirHound is offline
15 Knots.....Dang, who wouldn't take them off!
Doug
Old 07-31-2018, 02:04 PM
arffguy arffguy is offline
Default Paint?
I painted my tie-down rings.........but I haven't tried to screw them into the wings yet.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid in Feb anyway
Old 07-31-2018, 02:54 PM
I see many that are concerned about corrosion live in some humid and wet environments. Out here in Phoenix with a hangar I haven’t seen any corrosion issues on my Cherokee (29 years here) or my RV-12 (6 years). However, I used to worry about glass transition temperature when I had a WAR FW-190 at summer air shows sitting on the ramp.
Old 07-31-2018, 03:58 PM
Glass transition temp?
Doug
Old 07-31-2018, 04:17 PM
Default Everything?
Yeah, everything is coated. Go ahead and believe that, if you want. What about the stainless firewall and all the aluminum rivets and angles attached? And how about those cad played bolts? You know, the ones where the cad playing is removed during the tightening process... Look at a standard washer that has been previously tightened. You will find the cad plating has been removed.
Point is, dissimilar metals are a fact of life. Preventing corrosion can be as simple as applying a light coat of grease or anti seize to the threads...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 07-31-2018, 09:32 PM
Doug,
The older fiberglass epoxies lost strength if overheated. The critical temp was called glass transition temperature, and 30 years ago people tried to avoid painting dark colors on the fiberglass so it wouldn’t sit in the sun and lose strength. In Phoenix we can actually fry an egg on a dark surface on the worst summer days. GTT was something you had to think about.
Old 08-01-2018, 05:58 AM
DanH's Avatar
DanH DanH is offline
Doug,
Still do.....
Dan Horton
RV-8 SS
Barrett IO-390
