Old 07-28-2018, 07:15 AM
RV6-KPTW RV6-KPTW is offline
Default Dynon adhrs is loose in mount
Guys,
When I insert the adhrs in the mount, it does not have contact with the fluted side pieces and can move a little up and down. I can think of several ways to fix this but wanted to hear if others have encountered this and what has worked.
Dennis
Dennis Callaghan (KPTW -> X26/KMLB)
- RV14 sn:140193 - mostly done. Procrastinating on fiberglass
- 2000+ hours on my RV6!
- Dues paid 12/2018 * 2
Old 07-28-2018, 05:06 PM
Ok, ok, ok, ... is the suspense killing you?
I made a plate same size as the base of the adhrs out of .040 aluminum sheet. I slip it under the adhrs while slipping into the mount and it fills up the gap.
Wish I tested this fit before skinning the wing.
Woulda, coulda, shoulda...
