Old 07-27-2018, 09:40 PM
Jwputnam Jwputnam is offline
Default Belt tension torquing
OK....so how the heck do you torque the alternator belt to 140 inch pounds if the darn engine just turns over as I turn the alternator pulley? (No prop on yet)
Actually, I am a little surprised that the engine turns over so easily (new IO-320), but is there a way to stop it so that i can set the belt tension properly?
Sometimes these simple things frustrate the heck out of me and take far too much time!
Thnx!!!!
RV-9A
Will fly in the Spring of 2019
Dues paid annually (and very thankful for this site)
Old 07-28-2018, 05:54 AM
9GT's Avatar
9GT 9GT is offline
A 1 X 2 piece of oak board about 2' long. Drill a couple holes to match the prop flange and bolt it to the flange. Provides a handle to hold while you turn the alternator nut while checking the belt slip torque.
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
Old 07-28-2018, 06:00 AM
Kyle Boatright Kyle Boatright is online now
Put on a work glove and hold onto the flywheel/starter ring.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-28-2018, 06:50 AM
Default WELL, DUH
THE BOARD. So obvious. Why donít i see these things? Oh well, thanks.
Tried holding the flywheel. Didnít work for me, but thnx.
RV-9A
Old 07-28-2018, 07:40 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Just make sure to check it again after you have put the prop on - there can be a small change in geometry sometimes, unless you have the flywheel torqued to speck.
Personally, I don't do alternator belt tension until after mounting the prop, but there is more than one way to skin a feline....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
