Old 07-26-2018, 05:35 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Flop tube question
My project has a flop tube in the left wing. It will require extra elbows or sharp tubing bends to bring the tube to selector valve without routing it through the left footwell. Extra elbows are to be avoided due to vapor lock potential with FI.
The ship will only be configured for positive G aero (no inv’oil). So, is the extra elbows and bends a problem with FI ? I can convert to standard pickup or simply carry on with plumbing.
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 07-26-2018, 06:41 AM
Saber25's Avatar
Saber25 Saber25 is offline
Larry,
The flop tube is not necessary for positive G maneuvers. I removed mine some 20 years ago when I realized the heavy brass fitting was putting a wear mark on the bottom tank skin. The O ring failed and allowed metal to metal contact.
https://www.youtube.com/watch?v=P8uJYaJFst4
This was done with the normal fuel pickup.
Cheers, Hans
Build 'em light, keep it simple
I'd rather fly than tinker.
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight."
- Elrey B. Jeppesen,
Old 07-26-2018, 06:56 AM
Michael Henning Michael Henning is offline
I routed my fuel lines through footwell area with no issues of interference.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 07-26-2018, 07:09 AM
Default Thanks Mike
Got any pics of footwell path .
Decamplarry@gmail.com
765-505-1160
Larry DeCamp
Clinton, IN
Old 07-26-2018, 06:19 PM
SJordan SJordan is offline
I forgot to switch to my left wing with the flop tube and rolled inverted. Engine ran for a solid 30-45 sec before losing fuel pressure. I don’t see the need for a flop tube unless you have full inverted oil and plan on spending minutes at -2g. FYI I have Standard Bendix fuel injection on a Superior forward sump.
Shawn Jordan
KDVT
RV4. N11XZ
2018 dues paid.
Old 07-27-2018, 12:06 PM
TS Flightlines TS Flightlines is online now
Larry---we've plumbed alot of inverted tanks for guys. At the tank we use a long drop 90* hose end that routes through the tank nose bracket and crimps to a teflon hose. At the side skin, we 'either' is a 90* bulkhead fitting to connect the valve lines or make a longer hose to connect to the valve with a grommet at the side skin. A bunch of them out there, no issues we've heard of.
Tom
Ridgeland, SC
