Old 07-25-2018, 10:17 PM
Bsquared Bsquared is offline
Default Tailcone top side skin edge break
I figure most of the tech support is at Oshkosh so asking this esteemed group. Section 10 pg 30.....I am ready to dimple the top side skins. The plans do not call for the edge to be broken for a lap joint where the top skin overlaps the lower skin on the longeron. Edge break or not, that is the question.
RV-14A
S/N #140480 Empennage complete wings 90%
N144BL reserved
Dues paid for 2019
Old 07-26-2018, 05:06 AM
RV-14E's Avatar
RV-14E RV-14E is offline
From section 5.10...
"When riveting a lap joint, the expansion of the aluminum caused by the setting pressure and the expansion of the rivet causes the overhanging edge of the sheet to bend upwards slightly. This creates a number of problems, like making the lap joint appear wider than it is, making painting more difficult, etc. One easy method of minimizing this effect is by pre-bending the last 1/4 inch of the skin downward just a small amount before it is clecoed and riveted. When the rivets are driven, the skin will be flattened and the pre-set in the skin edge will tend to hold it flush. Except for very rare circumstances, the amount of bend (break) is very small and when done properly is almost undetectable with your eye. The goal is to do just enough to keep the skin lying flat but not too much or it will be obvious that it was done."
E
http://rv-14a.blogspot.com/
Old 07-26-2018, 08:27 AM
Thanks. I asked the question because up until now, and including the previous page for the top skin, the plans have reminded you to break the Lap edges. Seemed odd that they did not call it out here. I agree that the guidance in section 5 applies.
RV-14A
N144BL reserved
Dues paid for 2019
Old 07-26-2018, 08:49 AM
control control is offline
Its is not like for earlier models but even the 14 manual gets a little less detailed as you get closer to the end.
They kind of expect you to figure out the deburr part by yourself and sometimes even the edge breaking and dimpling)
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 07-26-2018, 08:53 AM
RV-14E's Avatar
As your confidence in the process develops, you'll find yourself asking fewer questions.
But it's okay, and good, to ask questions anytime you're uncertain. Keep asking.
E
