Old 07-24-2018, 09:20 AM
rvator10 rvator10 is offline
Default YIO-390-A3B6 Magneto Questions
The Lycoming website parts catalog shows the left magneto “Plane” Slick 4370 and the right magneto “Retard” Slick 4347.
What is the difference between the Plane and Retard magnetos?
Does this engine require the champion Slick Start (shower of spark) system?
If yes, which magneto would it connect to, the Plane or the Retard?
When "starting" the engine would both mags be on or just the left?
thanks
Old 07-24-2018, 12:18 PM
Jake14 Jake14 is offline
The Lycoming literature I got with my YIO-390-EXP10 shows the left magneto
66GC15SFNN LYCOMING MAGNETO-IMPULSE 4372
and the right:
66GP-0SANN LYCOMING MAGNETO-PLAIN 4370
(That's "plain" for non-impulse)
the impulse mag is usually on the left, at slow (starter) speeds it fires around 0 deg advance
The right mag is usually 'plain' without the impulse coupling and fires at whatever advance has been set (20 deg for the YIO 390)
The non-impulse mag should be off for starting to avoid kick-back due to the spark advance
I've got my mag switches wired so that the starter will engage only if the right mag is off
No slick start required
RV-14A #140158 flying
Old 07-24-2018, 12:36 PM
BobTurner BobTurner is online now
If you have an impulse mag, no Slick start needed.
If you have a RETARD mag, then the Slick start should be attached to that mag.
You can easily tell the difference between the mags. Slowly and carefully turn the prop (normal direction) by hand. If you hear a metallic ‘clunk’ near top dead center you have an impulse mag. In either case, you should disable any ‘plain’ (neither impulse nor retard) during start.
Last edited by BobTurner : 07-25-2018 at 01:35 PM. Reason: Big typo, fixed with all caps.
Old 07-25-2018, 04:04 AM
mike newall's Avatar
So.....
If you have a standard wired 'Cessna" key switch which is L, R, B, S - when you go to start, does it ground the right mag ?
Donated in 2018
Old 07-25-2018, 11:50 AM
Originally Posted by mike newall View Post
So.....
Most 172/182 Cessnas came with two impulse mags, so the answer is no. Most Pipers came with one impulse mag, one plain, so the answer is yes. There is an arrangement of jumpers on the back of the standard switch so it can be configured to do whatever you want it to do on start.
