Old 07-21-2018, 02:50 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Page 07-07 question
Steps 3 and 4 advise to only final drill the trailing edge, tip rib, and counterbalance rib where the flanges meet the skins. I would assume the rest of the holes are the newer RV-14 only parts that don't require final drilling (spar and stiffeners).
With that being said step 6 states debur all holes and edges that have not been deburred. Does it mean all holes that you Final / Match drilled in step 3 and 4 or "all holes"?
I only ask because it is a big difference in the amount of work. Thanks
Jon
RV-14A - N122X (probably)
http://www.mykitlog.com/mulde35d
Empennage Complete
Wings in Progress
Research on-going
Old 07-21-2018, 05:52 PM
RV-14E's Avatar
RV-14E RV-14E is offline
Deburring is one of the most time-consuming tasks of building.
Section 5.2 advises the following...
"All aluminum edges and corners must be smoothed and radiused to prevent this stress concentration from occurring."
and
"All drilled holes, or prepunched holes that have been final-drilled to a larger size, should also be deburred. Holes that were factory punched to final size can be inspected and only deburred if needed (with the exception of large holes to be dimpled for screws - see below)."
It's worth noting the caution also...
"Many novice builders deburr excessively deep. Deburring should not produce a significant chamfer/countersink on the edge of the hole. Be particularly careful deburring holes in .020 or thinner sheet. By the time both sides have been deburred the hole could be enlarged."
Speaking only for myself, I deburred all holes and all edges. As I look back on my time tracking spreadsheet, to give you an idea of how long that can take, I see I spent 4 hours and 39 minutes deburring just the top and bottom wing skins. I recall my hands feeling rather raw. To reduce the potential for RMI (repetitive motion injury), I obtained this to manage deburring.
You can use the power screwdriver with a deburring bit in conjunction with this adapter.
E
http://rv-14a.blogspot.com/
Old 07-21-2018, 06:07 PM
StressedOut StressedOut is offline
I deburr on condition. That is, I run my fingernail over the hole and if it catches the edge it needs to be deburred. Those rudder skins are 0.016 in. so a very light touch is required.
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 07-22-2018, 06:42 AM
mturnerb mturnerb is offline
Deburring is one of those topics - when it comes to pre-punched holes - that generates about as much controversy as primers. My own conclusions/observations after reading as much as I can find on these topics and deburring/building for two years is the following:
1. For thinner skins/parts, where holes are pre-punched fully to size (where instructions don't include any "final" or "match" drilling) deburring is generally needed only where there is a burr you can feel as previously mentioned. Deburring on thin skins has it's own risks - mainly chamfering the edge to a point where dimpling might over stretch it and increase risk of crack rather than decrease it. It's very easy to over-deburr thin skins/parts.
2. Van's and Synergy Air usually go straight to dimpling holes where rule #1 applies. Synergy does this with blue vinyl still in place.
3. I have found that if I scuff skins/parts that I intend to prime with ScotchBrite pads this removes burrs better than a deburring tool and has essentially zero risk of too much thinning of thin skins.
4. On thicker parts I usually deburr at least the "exit" side of the punch which is quite evident on inspection, and other holes (those pre-drilled fully to size) on condition.
Just my PERSONAL policy and process - your mileage may vary!
Turner Billingsley
RV-14A FLYING!!
Old 07-22-2018, 09:41 AM
mulde35d's Avatar
Much appreciated. I am also seeing good success with the scotchbrite pad doing the deburring work on the holes. Now if I could just find a cloth that was actually lint free for drying parts before priming then all my problems would be solved. (p.s. the ones that claim to be lint free haven't been so far)
Jon
Empennage Complete
Wings in Progress
Research on-going
