Go Back   VAF Forums > Model Specific > RV-4
Old 07-20-2018, 08:20 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default RV4 fuel selector valve location question ?
The drawings show the fuel selector valve in the forward left corner of the control stick "box". This would require me to loosen shoulder harnesses to reach in flight. That's not a show stopper for me personally, but I believe there is a requirement to reach it while "secured".
Before I invent my own solution, I would appreciate your input on where your valve is located and how you reach it. I am well versed in the discussion of "pointer vs. handle" and " pass through off, or not".
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 07-20-2018, 10:12 AM
acam37's Avatar
acam37 acam37 is offline
There is not very many choices when it comes to the fuel selector location. The top left is the most logical if you are holding the stick with your right hand. I have no problem reaching mine while belted in. You also don't have much room to route the fuel lines inside the plane. My current setup is about as simple as you can get it.
Arlie Conner
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 07-22-2018, 04:29 AM
Lufthans's Avatar
Lufthans Lufthans is offline
Ours is there too (although not quite a neat and clean as Arlies setup - wow). I've never needed to loosen my shoulder straps to reach it either...
That position just works. Why modify?
Hans Teijgeler
Hilversum, The Netherlands
Preparing to build a Rocket
PH-BRR Bowers Fly Baby; Imported and upgraded
PH-MGA Jodel DR1050; Built, with Subaru EJ25
PH-SUM RV-4; Imported and upgraded. Sold my share :-(
PH-EIL RV-4; Imported and upgraded for friend. Sadly crashed
PH-ERD Robin DR300; Built with Subaru EZ30 for friend.
