Old 07-19-2018, 06:24 PM
MalSmith MalSmith is offline
Default RV14 insufficient forward trim above 140KIAS
Hello all,
Whilst flying my RV14 taildragger i am experiencing inadequate forward trim over 140KIAS, with full forward trim the aircraft will sit in a nose up position and i am unable to trim for level flight.
The revised trim actuator arm from Vans was installed at the time of build.
I have heard from another RV14 builder that he had the same issue of not enough forward trim. The builder custom made a new trim actuator arm that was 5-6mm longer than the revised arm supplied from Vans. This has fixed his issue and he now has trim throughout the speed range.
Has anybody else experienced the same issue? If so how did you rectify the problem?
Any comments welcome.
Thankyou Mal.
Old 07-19-2018, 09:20 PM
n982sx n982sx is offline
I've always had enough nose down trim in my tri gear 14. The revised arm came out before my first flight so I have always flown with the new one.
Even at max aft CG it has always been plenty at any speed.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 07-19-2018, 09:37 PM
Tom023 Tom023 is online now
This is the first Iíve heard of a revised trim arm and donít see anything in the revisions. Was this a very early change? Information pointing to this would be appreciated.
RV14A #140083
Targeting July 1 for first flight.
2018 Donation+
Old 07-19-2018, 11:26 PM
Originally Posted by MalSmith View Post
Hello all,
Thankyou Mal.
Additional info regarding airplane configuration (engine and propeller that is installed, any other deviations from a standard built to plans build, etc.) would be helpful.
Scott McDaniels
Hubbard, Oregon
Old 07-19-2018, 11:56 PM
RV-14E's Avatar
RV-14E RV-14E is offline
Originally Posted by Tom023 View Post
This is the first I’ve heard of a revised trim arm and don’t see anything in the revisions. Was this a very early change? Information pointing to this would be appreciated.
Builders with empennage kits shipped prior to 10-Jul-14 were advised on 5-Nov-14 to contact Van's for a revised E-01401AB "Elevator Trim Pushrod Parts". The text of that notice was as follows:
"Van's Aircraft has determined that the existing Elevator Trim Pushrod has insufficient length for proper RV-14 elevator trim tab movement. For builders with empennage kits received earlier than July 10th, 2014, contact Van's and request a new E-01401AB Elevator Trim Pushrod. Fabricate and install the replacement Elevator Trim Pushrod per Pages 09-12 and 09-24 in the RV-14 fuselage plans pages.
Be advised that these Plans page updates have been posted to our website on 10-17-14. Please visit www.vansaircraft.com, click on Support, then Service Information and Revisions.
This is what the original pushrod would yield. This is explained in more detail here in this blog post.
Here's a comparison of the pre 10-Jul-14 pushrod (top) with the post (bottom).
As explained in this blog post, elevator trim travel is correct with the revised trim tab.
The original N214VA demonstrator, as of 7-Aug-14, did not use the same pushrod design. The picture below is from my visit to the home base on that day, outlined in further detail here.
E
http://rv-14a.blogspot.com/
Old 07-20-2018, 06:58 AM
The adjustable push/pull rod was used during the design testing process. The standard kit supplied (fixed) push/pull rod has been installed and in use for quite a few years now.
Scott McDaniels
Hubbard, Oregon
Old 07-20-2018, 06:50 PM
We have built an RV14 Taildragger, stock lycoming io390 with scimitar hartzell 74" prop. VPX ECB and dual G3X displays, stock standard installation.
When testing the trim the aircraft had full fuel, both pilots weights were 91kg and 89kg respectively and there was nil baggage on board.
The link below has a detail of the revised trim actuator that was installed as specified by Vans.
Thankyou for taking the time to reply and for the information received to date.
https://photos.google.com/share/AF1Q...ZGX3pRQnZVR0Fn
Old 07-20-2018, 06:58 PM
Super Moderator
Hello all,
Thankyou Mal.
Hmmmm. I havenít seen this. I have flown the demo RV-14A at max gross weight, including max baggage, and I see the auto trim barely moves forward in cruise flight. Iím inclined to think ther may be something else going on with your airplane. Donít hesitate to contact me and we can discuss.
Vic
Vic Syracuse
Kitplanes "Checkpoints" monthly column
www.Baselegaviation.com
